Control Wiring
Looking for a wiring diagram for the Genie GR-15
  • Posted 28 Feb 2021 05:22
  • By hawk84
  • joined 28 Feb'21 - 3 messages
  • Glamorgan, United Kingdom
it sounds like either the lift drive selector switch is not changing the circuit and when you move the joystick it is driving even though you have it in lift mode.
I would check the switch and make sure it is working correctly
also i would also check the control relays CR52 and CR51.
  • Posted 3 Mar 2021 11:40
Hi Thanks for responding.
I have contacted Genie and am awaiting a reply.
I do seem to have a strange problem with our GR-15.
When it is switched to ground controls the platform raises and lowers correctly.
When it is switched to Platform controls and switched to drive the machine drives forwards and backwards and steers correctly.
But when it is switched to Platform controls and switched to lift position, the top alarm on the base unit sounds constantly and when you try to lift the platform the unit drives backwards.
  • Posted 3 Mar 2021 01:24
  • By hawk84
hi hawk,
yeah i was looking in the book and it does not have that specific schematic number in it. They start at ES0083B on page 6-6 for that serial number range. That one should be the same as your unit. You can contact genie and see if they have that specific schematic number though.
I can say the wiring in these units does remain very similar across the board unless they make any upgraded additions or design changes.
You can also look in the literature box and see if that specific schematic was included with the lift, usually it would be in there if so (providing it hasn't been removed at some point).
  • Posted 2 Mar 2021 00:10
Hi Thanks for the reply.
I cant seem to find the correct drawing for the model I have, unless i am missing something.
The Nameplate on the lift shows:
Model GR-15
Serial No. GR03-2347
Model Year: 2003
Elec/Hydr Schematic: ES0084.
Not sure if can upload a photo of the nameplate on here, so you could see all the details.
  • Posted 1 Mar 2021 19:38
  • By hawk84
hawk,
you can go on genie's website and get the literature you need, it is not restricted, it is open for public consumption and what you seek is there ;o)
  • Posted 1 Mar 2021 02:17
