Constant error codes 283 and 293 while lifting
Hello there, Anyone else have these order picker liftrucks in their route. I have changed the prox. switches, sensor bearings, cam follower wheels are tight and clean. Lifting heavy pallets or nothing the codes are constant. Tks. in advance
  • Posted 19 Mar 2013 09:43
  • By Torch
  • joined 19 Mar'13 - 1 message
  • British Columbia, Canada
Ok thanks for the update. The original fault was they damaged the card at the front between the 2 forks. So they replaced the card off another order Picker which had a shorter mast.
Since then they've had this error so could it be the card needs programming?
It shows the height as 4.7 metres but actually lifts to 7.1 however in the parameter reference it just shows 4.7.
Not sure how to program it, as I've been in tried calibrate with just start.
Yet once second stage mast comes in the faults 293.
  • Posted 23 Aug 2025 06:51
  • By elektrodrive
enquiries@elektrodrive.co.uk
I haven't dealt with such old pickers for a long time. Mostly they had problems with the mast cable, but there are backup cores there. According to 293 errors, I think the height sensor was damaged
  • Posted 23 Aug 2025 06:26
  • By pavel_y
  • joined 27 Jan'16 - 52 messages
  • Donetsk region, Ukraine
Specialized repair of electrical equipment warehouse. Repair of controllers and components
Hi i know it's been years since this was posted but anyone work out what error code 293 is when second stage mast operates? Then slows the truck down in drive and lift
  • Posted 23 Aug 2025 06:12
  • By elektrodrive
Briefs United States
Maxlion MTF25-60-2WD
SMV (Konecranes) 12-1200B
