code GB,f8,steering out of restricted area
working on a easi-40 s/n EF-A-04-31291 the right outrigger wheel will go straight at when the red centering button on the glass is pressed then turn side to side no matter were the steer wheel is located. the GB code appears after the self test and the steering code appears when you turn the wheel full to one side or the other.i didn't put much time in trouble shooting the unit because customer was shutting down for the night by the time I got there.befor I go back I want to have a thought as to were to start. also how do I get into the dash to do the steering learn on the unit.
  • Posted 7 Dec 2014 16:27
  • By wrenchman
  • joined 7 Dec'14 - 6 messages
  • New Jersey, United States
Check the switches on the outrigger and the prox switch next to the drive unit. Sometimes the cable for the prox gets rubbed and loses connection. The switches on the outrigger can get hit and miss adjusted. Check the cable to the switches for damage as well.
  • Posted 12 Dec 2014 01:06
  • By lifttrainer
  • joined 14 Apr'11 - 16 messages
  • Tennessee, United States
