code 739
Hi, I have change the hydraulic pump and I have remove the tilt cylinder from the mast. After re-assemble, the tilt don't move and code 739 is on. I need help
  • Posted 16 Sep 2016 08:53
  • By mechanicmaster
  • joined 12 Jun'14 - 15 messages
  • Quebec, Canada
Take you feet off both footpedals and after a few seconds the Calibration option should appear while you're scrolling through.
  • Posted 21 Sep 2016 05:06
  • By techno_nz
  • Canterbury, New Zealand
Yes we have removed the right tilt cylinder. The tilt sensor need to be calibrated.
  • Posted 20 Sep 2016 04:34
  • By mechanicmaster
  • Quebec, Canada
How I can acces to menu c2.1? I found analyser, performance, events, etc, but I don't found ¨calibration¨
  • Posted 20 Sep 2016 04:33
  • By mechanicmaster
  • Quebec, Canada
The tilt position sensor (RPS2) is above or below the calibrated range. Did you remove the right hand cylinder as you stand on the truck facing the mast? Thats the one with the tilt position sensor. Maybe you didn't engage the potentiometer arm correctly. You can check RPS2 voltage in Analzyer menu A2.4.8.1, 2.2v = 5deg fwd tilt, 2.8v = mast vertical, 3.3v = 5deg back tilt.
RPS2 can be calibrated in Menu item C2.1
  • Posted 16 Sep 2016 18:54
  • By techno_nz
Enforcer FD50T-MMA
SMV (Konecranes) SL37-1200A
Enforcer FD50T-MMA
