Code 556
I have error code 556. Unit loses travel until reset. Problem occurs after 1hr of use. Assistance appreciated.
  • Posted 17 Jun 2015 05:36
  • By trutechrmc
  • joined 12 Aug'12 - 6 messages
Your welcome, hope it helps
  • Posted 23 Jun 2015 07:30
  • By Robk
  • joined 20 Jun'15 - 9 messages
Thank you very much. I will check that out. I appreciate the info.
  • Posted 23 Jun 2015 07:07
  • By trutechrmc
If voltage is 5v....
Keep the truck ON. Use ANALYZER MENU/
A2.5.1 ECR2 to show the counts when you turn the
steering wheel clockwise a
nd counterclockwise. The
counts should change smoothly and continuously as
you turn the steering wheel. Record the counts when
the steering wheel is in the neutral position.
  • Posted 20 Jun 2015 09:55
  • By Robk
Robert k
Turn the truck ON. Measure the voltage be-
tween CA410-2 and CA410-4.
The correct voltage = 5 V.
  • Posted 20 Jun 2015 09:51
  • By Robk
Robert k
Are you sure its a 556?
  • Posted 20 Jun 2015 09:39
  • By Robk
Robert k
Ok give me a minute let me see what I find about that code...thanks
  • Posted 20 Jun 2015 09:35
  • By Robk
Robert k
Hi. I am working on a crown sp4020 orderpicker.
  • Posted 20 Jun 2015 09:34
  • By trutechrmc
Hey! Is it a 3/4/5 wheel stockpicker? Also if you could supply serial # thatll help also!
  • Posted 20 Jun 2015 08:58
  • By Robk
Robert k
Nagano NUZ090D
Taylor TT300
F. Uchiyama
Nagano NUZ090D
Taylor TT300
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
