Code 524260-1
Apparently this is a ground short issue. Looking for advice on where to start looking. This unit has multiple codes. Starts great, runs 30 seconds then shuts down. Throttle is unresponsive while running.
  • Posted 10 Jun 2022 01:19
  • By Ed_Breen
  • joined 10 Jun'22 - 1 message
  • Saskatchewan, Canada
Go after the simple problems first.
Is the battery more than 3 years old ?
Is the battery maintenance free ? Or Lead Acid/might need water.
Is the bolt that secures the Negative cable loose or corroded ?
  • Posted 15 Jun 2022 17:46
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
You will have to follow the wire harness to see if you can find anywhere the 5v may have rubbed through and touching ground. Remember all 5v are the power to all sensors. They do break it up on to segments from vsm.
  • Posted 10 Jun 2022 10:05
  • By TONY_DREIER
Sue Tomic Sue Tomic
