code #30106
Truck fell off truck smashed tiller handle. swapped out with a good one but still same code. also controller blinking 1 red 5 yellow than 2 red 1 yellow than 1 red 6 yellow and finally 2 red 9 yellow. Have no books or info on this truck. company just purchased 4 new. Can anyone help?
  • Posted 18 Aug 2018 03:50
  • By Deuce
  • joined 27 Jan'16 - 26 messages
  • Michigan, United States
Never found info to calibrate card. Installed new card and handle/housing and solved issue.If you have another unit i would try swapping card between the 2 and see if code changes to the other machine. If it dosent than that will rule out card needing calabration and problem lies somewhere else.
  • Posted 13 Nov 2020 22:08
  • By Deuce
Jeff Sheldon
I'm having same fault with a mpv045vg, replaced the tiller control and housing. Can you share the process to calibrate? Thanks
  • Posted 12 Nov 2020 23:45
  • By Osvaldo_Padilla
  • joined 12 Nov'20 - 1 message
  • Indiana, United States
If you could give me the link i would appreciate it. Thank you.
  • Posted 6 Apr 2019 01:09
  • By Deuce
The problem is the tiller card and the wire harness for the tiller card, once a tiller card has been replaced, you need to calibrate, calibrating them is quite a bit of fun, find the process for that then that should solve your issue, if you are unable to find the process I can paste a link if this issue hasn't been solved yet, thanks
  • Posted 5 Apr 2019 12:19
  • By joshua_h
  • joined 1 Feb'19 - 8 messages
30106
The tiller board fails to communicate
with the Combi controller via
CANbus.
Possible causes:
A. CANbus communication error -
no reception of the message via
CAN
B. Error in the tiller board wiring harness
- short circuit or open circuit
on pins 23 and 35 of the Combi
controller.
Carry out a visual inspection of all the connectors paired with the error code.
Restart the truck and check whether the error code is still present.
* Check the wiring harness between the Combi controller (pin 23 and pin 35) and
the tiller board (CRS 18 connector pin 4 and pin 3).
* Check that the connectors are clean.
  • Posted 17 Sep 2018 15:44
  • By dato_georgia
  • joined 15 Aug'18 - 34 messages
  • Georgia
Thanks that should help. At least point me in right direction. Have new tiller card and upper lower housing along with Steel handle on order.
  • Posted 22 Aug 2018 02:29
  • By Deuce
A. CANBUS COMMUNICATION FAULT
B. TILLER CARD WIRING FAULT
C. FAULTY HANDLE
  • Posted 18 Aug 2018 06:32
  • By BREWSKI
Taylor T650L
Nagano NUZ090D
Kai von Berg Kai von Berg
Bolzoni SpA (Group HQ)
