Report this forum post
The problem is the tiller card and the wire harness for the tiller card, once a tiller card has been replaced, you need to calibrate, calibrating them is quite a bit of fun, find the process for that then that should solve your issue, if you are unable to find the process I can paste a link if this issue hasn't been solved yet, thanks
  • Posted 5 Apr 2019 12:19
  • By joshua_h
  • joined 1 Feb'19 - 8 messages
  • Michigan, United States
Indicates mandatory field
