code 2V
machine is flashing a 2V code , code is not listed in service manual.
Bad battery or cells ???
  • Posted 8 Mar 2016 07:41
  • By primernova66
  • joined 8 Mar'16 - 1 message
  • Wisconsin, United States
Hi,
Did you fix this problem, I have the same and can't figure out.
  • Posted 14 Jul 2016 07:25
  • By escol
  • joined 27 May'07 - 8 messages
jescobar@escolcorp.com
replace the 3 relays on the fuse card
  • Posted 11 Mar 2016 12:17
  • By EasiTek
Traction is disabled. Cycle key
switch to clear. If code occurs
during plugging, replace all
battery cables and connections
that show signs of heat or
corrosion. Install a battery that is
in good condition. If code persists,
replace the TPA.
Note: The VM cannot cause this
code.
  • Posted 11 Mar 2016 00:45
  • By lifttrainer
  • joined 14 Apr'11 - 16 messages
  • Tennessee, United States
