Code -165
Crown with code -165? Do not have a manual anybody have any ideas for this code?
Also am setting a 66 code in slave controller.
  • Posted 6 Jan 2017 05:43
  • By JAYS
  • joined 16 Apr'16 - 26 messages
  • Iowa, United States
Code 165 isn't in the manual. Code 66 is FIELD FET CURRENT EXCEEDED EXPECTED CURRENT LIMIT. Check drive motor connections, resistance (motor armature to field & both to chassis), shorts on all suppressors Inc fan/horn/etc.
Check 36v at CA401-18 with seat switch open.
If all good, could be a controller.
  • Posted 6 Jan 2017 09:08
  • By techno_nz
  • Canterbury, New Zealand
Linde Material Handling
