Clutch will not disengage
I have had this forklift for quite a few years and other than normal maintenance it has been trouble free. The previous owner must have had some clutch issues because I noticed they welded an extension onto the rod linkage going from the pedal to the trans. All of a sudden the pedal won't do a thing but it is stuck in an engaged position. We can use the forklift by starting it in gear-I know this isn't good but it is the only way it will move. This is obviously a pain because we are constantly turning it on and off.
My guess is that the clutch is rusted/stuck to the flywheel but any advice to help free it up would be appreciated-especially if it involves NOT pulling the transmission out!
  • Posted 7 Oct 2008 04:06
  • By Brad19801
  • joined 7 Oct'08 - 1 message
  • Delaware, United States
hello brad.this is probably a stupid question but have you tried disconnecting the linkage to see if the clutch dissengages?
  • Posted 7 Oct 2008 07:43
  • By tugmaster
  • joined 25 Aug'08 - 73 messages
  • United Kingdom
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
Lift Tek Elecar
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Lift Tek Elecar
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
