Clark electric - forks work but will not drive
Hi everyone. I am hoping someone might have an answer to my situation. I just bought (today actually) a used Clark electric forklift. It was delivered to my warehouse and after being winched off the flatbed it was driven (under its own power) into my building. I was shown that the forks work properly and after having seen it drive into the building assumed that was fine too. Shortly after the guy who sold it to me left, we set about using it and it drove no more than ten feet and simply stopped moving. The forks still continue to move up and down freely but no forward or reverse. I have a large three phase charger but the forklift and the charger are in two different parts of the building. I do have a small golf cart type 36 volt charger hooked up to it for the time being to see if it may just be a matter of charging, but I thought that these were designed to have the forks stop before the battery was too low so it could still limp to the charger. I should also mention that there is no battery gauge present. Any help would be greatly appreciated. Thanks for reading!
  • Posted 29 Apr 2016 09:32
  • By RoseCity
  • joined 29 Apr'16 - 1 message
  • Indiana, United States
Depending on the model (I.e. ECS 20 circa 1989). The truck is equipped with an SCR panel behind the rear cover. More than likely, it experienced a PMT event (pulse monitor trip). You could spend a ton of time testing components. If the issue is more apparent at creep speeds check the drive motor brushes and armature condition before we continue.
  • Posted 24 Aug 2016 14:14
  • By Dfraz916
  • joined 25 Mar'16 - 6 messages
joel n ``did you ever get a answer on this problem. i have a unit with the same problem
  • Posted 17 Aug 2016 00:54
  • By wdgiel
  • joined 17 Aug'16 - 1 message
  • New Jersey, United States
hey did you get the problem fixed- I have a lift with the same issue.
  • Posted 16 May 2016 04:52
  • By joel_n
  • joined 5 Sep'15 - 2 messages
You're going to have to list the model and serial number to get any ideas.
  • Posted 29 Apr 2016 20:17
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
UN Forklift FD25T-C2JM1
UN Forklift FGL18T
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
UN Forklift FGL18T
