Changed Fluids, Now Crank No-Start....
I bought a Hyster YC-40 off craigslist for $800.00. It was starting and running just fine. I changed the Hydro Oil, Engine Oil, and Transmission Fluid. Now, it will crank but not turn over. This is extremely puzzeling? Any ideas?
Thanks in advance for your help!
  • Posted 6 Mar 2012 10:31
  • By UglyShinglesLLC
  • joined 6 Mar'12 - 2 messages
  • Michigan, United States
i would check the battery and load test it to see if its ok,then check the starter,sounds like it is dragging or needs rebuilt/replaced. Do a voltage drop test from the battery to the solenoid and a drop test on the negative cables,check for good ground connection on negative cable from battery.
  • Posted 6 Mar 2012 10:46
  • By kevin_t
Yes it cranks and trys to turn over. If I hold down the gas pedal it almost makes it.
  • Posted 6 Mar 2012 10:43
"it will crank but not turn over"?? Does it just make a click or does the starter turn the flywheel and just wont fire?
  • Posted 6 Mar 2012 10:38
  • By kevin_t
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
Lift Tek Elecar
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
