change parameters and charge voltage
Hi everyone!
I buy this multi-charger to recharge 12v, 36v and 48v batteries.
At the moment of connecting the charger to the battery, it does not recognize the 24 cells (48v), only 18 cells (36v). I have not tried 12 cells (24v).
Some code is needed to modify the menu and recharge my battery?
Thank you for your attention.
regards
  • Posted 4 Mar 2022 14:04
  • By Manuel_Flores
  • joined 4 Mar'22 - 1 message
  • Mexico
Manuel Flores
The charge carried by a bolt of lightning is so intense that it has a temperature of 30,000-degrees C (54,000-degrees F), five times hotter than the surface of the sun which is about 5,500-degrees C (10,000-degrees F).
