Caterpillar orderpicker N0R30P fault codes
Hi, first time posting. Can anyone help with this? I use this electric machine (Cat N0R30P) every day, and frequently it gives either code '80' upon startup, or sometimes code '84' during use. Does anyone have a list of codes, or have experience with this? Thank you!
  • Posted 13 Jan 2012 16:25
  • Discussion started by PreBoxer
  • Missouri, United States
CJ code: Reconnect the plug on the steer encoder on the left side of the drive motor.
  • Posted 4 Oct 2019 02:17
  • Modified 4 Oct 2019 06:29 by poster
  • Reply by Service_T
  • Kansas, United States
ServiceT
I'm got a nor30p coding CJ anyone help
  • Posted 3 Oct 2019 00:07
  • Reply by lerk1965
i have a nor30p coding a 41 only over rough areas. i have tightened everything, still codes.. any ideas
  • Posted 3 Apr 2019 04:09
  • Reply by Bwkw
Agree with over the mast cable as stated above, but have also seen Code 80 triggered by bad carriage interface board several times.
  • Posted 6 Jan 2018 02:44
  • Reply by Techtrainer64
  • Kentucky, United States
80 is the magic code
  • Posted 5 Jan 2018 06:47
  • Reply by LUMBER1
Someone should mention that while the pots in these trucks do not last as long as most would like, these same codes can and do result from an internal breakage in the "over the mast" cable that runs from the carriage to the tractor portion.
Based on the symptoms, almost for sure your problem and best solution is to replace the pots then relearn them.
  • Posted 26 Jan 2012 05:50
  • Reply by edward_t
Code 80 and 81 are for throttle pot and lift pot out of range. You can relearn the pots all day, they are out of range and learning does nothing.
Code 80 - The throttle pot analog input was detected below 0.156 volts or
above 4.844 volts.
Code 81 - The lift pot analog input was detected below 0.156 volts or above
4.84 volts.
When the controller see these voltages is when you get the code 80 or 81. Relearn until you are blue in the face, the voltage is out of range.
  • Posted 26 Jan 2012 04:42
  • Reply by LTRM
  • Illinois, United States
Thanks to both of you, 7777 and radon.
It's an old lift, and the last time someone from our local equipment co. was out to look at it was 4-5 months ago. He mentioned relearning those, and up until now it's worked "ok". Occasional problems. It has shown slight movement during self test recently, usually reverse, then usually codes out.
  • Posted 14 Jan 2012 16:09
  • Modified 14 Jan 2012 16:10 by poster
  • Reply by PreBoxer
7777 is right, 80(accel pot) and 81(lift lower pot) are common faults, sometimes you can relearn drive and lift pot. and it will be good for abit. Alot of times they need to be replaced. Code 84 is a brake code, but also could be a speed pot on top of the drive motor issue. The controller is seeing movement when the drive transistor is being tested during self test.
  • Posted 14 Jan 2012 03:44
  • Reply by radon
code 80 - throttle controller analog reading out of range
code 84 - brake misadjusted
  • Posted 13 Jan 2012 19:34
  • Reply by 7777
