Caterpillar M50DP with error code F5
Hi all,
I have a Caterpillar M50DP which runs for about 15-30min, then will not move. The hydraulics still work, and the panel comes on, but the drive wheels stop working. The battery is fully charged, and the code I'm getting is F5. Looking on the back of the rear panel covering, F5 means "drive system failure, consult service manual".
Any idea on what might be going on?
Thanks!
  • Posted 19 Jul 2020 05:50
  • By karter3000
  • joined 19 Jul'20 - 1 message
  • British Columbia, Canada
i know its been a month since you posted but thought i'd throw in some info in case you're still stumped.
F5 indicates a fault in the drive system (we already know this)
the possible causes listed for that code are:
-Faulty: wire connections @ T1D, T2D, or (T3D if equipped).
-Failed: current limit set too low, failed D5D or D4D.
-Failed: driver board or failed logics
I would test the drive transistors and all the diodes and make sure none are blown.
the drive transistors are known to cause issues like this so i'd test them first.
  • Posted 16 Aug 2020 01:08
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
