Caterpillar C5000
Cat C5000, Serial AT9003401.
Im having trouble with the trans. it doesnt muves. If you select fw. direction machine does not muves and the ligth in the dash is in neutral position.If youselect reverse the ligth remais in neutral, the alarm sounds but still doesnt muves. I have checked the lever, seat switch,trans. solenoids and everithing seems ok.
The vcm has a red light flashing inside.
Any one can help to solve this issue
thanks for your help.
  • Posted 11 Feb 2014 04:48
  • By pastrana_j
  • joined 3 Aug'10 - 103 messages
  • Puebla, Mexico
Showing items 1 - 16 of 16 results.
Swoop can you give e me color codes for tps sensor that correspond to the ones you dis used concerning the tps on pedal please. Thanks
  • Posted 7 Jun 2022 02:32
  • By Vernon_Jackson
  • joined 7 Jun'22 - 14 messages
Vernon
joselyn,
first off starting a new thread for your problem instead of hijacking this thread would be more appropriate and less confusing for those that were following this threads original subject.
secondly you seem to be going at this all wrong
the code E27 is most commonly caused by old worn spark plugs where the electrodes have burned away and the gap has widened so far that the ECM cannot compensate for the difference in spark timing so it sets the POS sensor code because it is changing the cam angle sensor reading so far it cannot compensate any farther so it starts operating out of range expected.
Try changing the spark plugs.
Also a coil pack may be misfiring so check the harness plugs and wiring there and make sure there is not a broken wire to any of the coil packs or that there is no coil pack failing.
I think you will find the spark plugs may fix this though.
The code E23 is for the 'throttle' sensor not the pedal sensor. There is no adjustment for the throttle sensor, it is self calibrating when the ignition is cycled on and off and on again.
If you keep getting this code then there is a problem with the sensor assy inside the throttle assembly or there may be a broken wire at the harness where it plugs into the throttle body.
Broken wires were very common with these so that may be the case, on rare occasions i have found the throttle body gear set inside it were not lubed enough during assembly and it would hang up, (not returning to rest position completely), this can make it set a code when self calibration occurs. Sometimes cleaning it out and relube fixes it but in most cases i wound up replacing the throttle body in the long run.
If you have been fiddling with the pedal position sensor you need to use a volt meter or have a laptop connected so you can get it set to the correct voltage it expects to see when the pedal is fully released. You also want to check the pedal position stop bolt and linkage set pin make sure it is not broken or out of adjustment.
In some cases the pin that holds the linkage and actuating lever breaks and has to be replaced or repaired.
the voltage for the pedal sensor voltages should read the following
key on engine not running pedal position fully pressed:
Terminal 106 Accelerator pedal position sensor 1 Approx. 4.2V
Terminal 98 Accelerator pedal position sensor 2 Approx. 2V
with pedal released fully the readings should read:
Terminal 106 Accelerator pedal position sensor 1 Approx. 0.6V
Terminal 98 Accelerator pedal position sensor 2 Approx. 0.3V
I would suggest getting a cat tech out to hook up the laptop as that would make things alot easier.
These codes will not clear out no matter what you do if the condition is still present so disconnecting the battery will not do anything either. And besides even though disconnecting the battery can clear codes it can also set codes because it will loose some calibration settings when the ECM memory clears and that will have to be redone.
  • Posted 13 May 2015 23:31
did you test the trottle sensor
  • Posted 13 May 2015 06:25
  • By mikeb
  • joined 22 Jun'13 - 38 messages
work smarter not harder
yes we've done that...I was thinking maybe in the manual there might be a different way or idea.
  • Posted 13 May 2015 06:15
  • By joeselyn_aaa
  • joined 30 Sep'14 - 10 messages
  • PR, Puerto Rico
Pull the battery cable and let it sit overnight. Works on some different applications
  • Posted 13 May 2015 04:36
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
the forklift is not accelerating. Computer was checked and it is OK. but since we don't have a scanner to delete the codes we are doing it manualy and trying to possition the throttle. so far...no luck.
  • Posted 13 May 2015 04:33
  • By joeselyn_aaa
  • PR, Puerto Rico
what do you want know. what problem are you having.e-23 is throttle position e-27 is cam or crank position
  • Posted 13 May 2015 01:20
  • By mikeb
Does anyone has the code actions for C5000/P5000? I'm searchin a couple of codes. E23, E27, etc. Please advice.
  • Posted 13 May 2015 00:17
  • By joeselyn_aaa
  • PR, Puerto Rico
good deal pastrana
since your going to replace the meter panel i will not have to check, they will give you one that is already up to date.
  • Posted 18 Feb 2014 15:29
Problem solved. I got a panel from a sister truck and everything worked fine.now customer is thinking for a new display.
Thanks to all for your help.
  • Posted 18 Feb 2014 11:31
  • By pastrana_j
  • Puebla, Mexico
Thanks a lot for your help. I will be back tomorrow to this machine.and will take care with display and wiring.
  • Posted 13 Feb 2014 09:26
  • By pastrana_j
  • Puebla, Mexico
yeah jeremy it could also be a meter panel
cat sent out an update and there was a certain number of meter panels that were mandatory updates depending on the code on the meter panel. If his dealer was on top of it that should have been replaced long ago.
if he can get the numbers off the side of it and post them back here i can check to see if his has been updated or not :o)
  • Posted 13 Feb 2014 08:14
Probably meter panel, I have had this problem before. The meter panel will not help the E 21 though
  • Posted 13 Feb 2014 01:22
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
i doubt the nissan wiring would be exactly the same... it may be similar but i would not use a nissan wiring diagram, use a cat one for that truck. sent you some visual aid :o)
DTC code E-21 is Air Flow Meter Signal Fault
Check the wires on the MAF sensor on the air intake, you will probably find one of them is broken internally. If you tug on them and there is a break it should pull apart at the break. You can then solder it back together. Then do the pedal dance to clear the codes and run the truck again.
i don't think that would disable the transmission but take care of the code first.
  • Posted 12 Feb 2014 06:20
  • Modified 12 Feb 2014 11:45 by poster
Yes code E 21 is showing in display and the neutral ligth does not blinks. If you muves fw or rev the ligth is always in neutral.
Do you know if the nissan platinum II wiring correspondes to the cat machine.
  • Posted 12 Feb 2014 03:38
  • By pastrana_j
  • Puebla, Mexico
look on the hour meter display when you put in direction and try to drive and see if any codes are showing.
does the neutral light blink when trying to select direction?
  • Posted 11 Feb 2014 21:48
Crown RR5225-30TT321
Mitsubishi FD200
