cat 6500 forklift ECM
I am in dire need for a place to buy a electronic control modual for this cat 6500 with a nissan K25 engine the numbers on the modual are 3 NANN other # are Mec34-082 A2 5829 also # 23710 GY41b Hitachi brand ecm can any body could help me ???????? thanks jim
  • Posted 12 Dec 2009 22:21
  • By jaguarjo
  • joined 12 Dec'09 - 5 messages
  • baghdad, Iraq
It would be wonderful if you could help us troubleshoot this problem. we are very limited on books or equiptment to work with. a long while several months ago one of my men said there was a throttle position sensor code E 23. as i was saying before it will run when i interduced gas in the throttle body. there is fuel to the injectors there is fuel pressure. There is fire to the spark plug. The main relay& egi relay has voltage to it it also has voltage leaving it to the ecm. Execpt relay #1 has 0 voltage and seems to work but # 141 a W/G wire has 0volts leaving the relay going to the ecm. when in the ignition is in the on position 12 volts in the off position.There is voltage at each injector when installing a noid light the light will not pulsate. telling me there is no injector paulse , therefor no fuel in the combustion chamber. we hav no resorse to ANY AMERICA dealers or otherwise we also have no sorce here in Iraq. thank you for your help
  • Posted 13 Dec 2009 15:01
  • By jaguarjo
  • baghdad, Iraq
jim
what is the truck's serial number?
do you have any American purchasing contacts?
  • Posted 12 Dec 2009 23:07
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Nagano NUL120-6
