CAT 2EC30 Status Codes
Working on a Cat 2EC30 Serial A2EC360258, currently has a status code 10, been told 11 and 28 show up at times. currently the unit does not run. anyone have any documentation of this unit. thanks
-matt
howitt937 at gmaildotcom
  • Posted 26 Jan 2013 23:00
  • Discussion started by Howitt
When we leave the truck unplugged for a while the truck will work but will then shoot off into top speed. I've replaced the contacts and the drive board but still have same problem.
  • Posted 30 Apr 2020 19:40
  • Reply by garylee_p
  • Shropshire, United Kingdom
what system is in it?
ev100zx? or microcommand?
ev100 card is mounted at top of panel in horizontal orientation
microcommand is laid flat on upper part of panel vertical
i checked in ev100 troubleshooting and there is no code10
but in microcommand there is a code 10
the causes are listed as follows:
- shorted T1D or T2D
- shorted bypass contactor tips
- open wiring
- failed drive driver board
- failed logics
- slow bypass contactor
remove the logics card and there will be 4 transistors mounted on the boards behind it
The left board is the hydraulic driver board
The right board is the Drive driver board
T1D is transistor mounted top right
T2D is transistor mounted bottom right
  • Posted 29 Apr 2020 06:50
  • Reply by swoop223
I've got a problem with code 10. Would the drive motor armature transistor be on the drive controller card?
  • Posted 29 Apr 2020 00:51
Hello all, I'm working on a 2EC15 with a microcommand system. Can anyone tell me what is code E21?
  • Posted 27 Jul 2017 01:44
  • Reply by jose_z
I bet its a stuck contactor, once I get up there to look at it
  • Posted 28 Jan 2013 23:41
  • Reply by Howitt
this truck comes with either an EV100ZX system or a Microcommand system.
The codes you say come up 2 of them do not exist in the code list for the EV100 system so we will assume that this truck has the Microcommand system.
If that is so then:
Code 10 = Drive Armature transistor fault (high)
Code 11 = Drive Armature transistor fault (low)
Code 28 not on the codelist
now there is a code 38 for pump shunt field transistor drain fault (high) or a code 26 for accelerator fault (high)
all these codes will result in no lift truck operation.
the troubleshooting guide for these codes is rather extensive in what to check as the causes of these codes but i would first check for stuck contactors. Also make sure the battery is fully charged. There is also mention of shorted T1D and T2D transistors.
These are good places to start your checks
Good luck
  • Posted 28 Jan 2013 22:56
  • Reply by swoop223
check your e-mail
  • Posted 28 Jan 2013 13:25
  • Reply by kmj_f
  • COLOMBO, Sri Lanka
edition #1235 - 19 June 2025
