c500y80 Brakes
No brakes. Checked fluid levels and bled. Also parking break will not engage.
  • Posted 19 May 2013 03:35
  • By harry_d
  • joined 19 May'13 - 2 messages
  • Alabama, United States
You probably have repaired by now, but if not, post if it is 355 or 685 and I can give you guidance.
  • Posted 23 Dec 2013 02:19
  • By Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
Thank you for responding. We were able to get brakes working by cleaning inching spool and re bleeding system. Now the steering cylinder is leaking badly. Have remove rear connector. Cannot get front connector to budge after removing nut and washer and using mallet. Do you have a suggestion. We do not have a lift
  • Posted 20 May 2013 23:00
  • By harry_d
This truck should have two master cylinders on it one for the inching(left brake pedal) and one for the service brakes(right pedal)......which one(s) did you check?
The brakes shoes on this truck are internal to the axle assembly so is a little different doing a brake job on this truck...the Parking brake is a separate drum on the Transmission and is adjustable....if the shoes are still in good shape that is??is just a small five inch diameter drum that you should be ale to find if you follow the park brake cable down to it
  • Posted 20 May 2013 01:12
  • By kevin_t
edition #1285 - 11 June 2026
Stu Jacover Stu Jacover
Chief executive officer, TVH
