C25P Clark Forklift Resurrection
Hi all,
I'm trying to help my uncle with an old Clark lift truck that he has.
Per the serial number plate, it is a Model C25P, with a Continental Y112 engine. It is currently set up for propane, and has run in the past. He wants to start using it again, and wants to change it to run on gasoline, as it will only be run outside to move firewood and such, and he already has gasoline around for his other equipment.So, obviously the carburetor will have to be changed. In my research it looks like the gas version of these had a Zenith 68-8 carburetor??? But, there is also Zenith 12522, and others, listed for a Continental Y112 engine. And then, NUMEROUS Marvel-Schebler carbs in the cross references. So, I was hoping maybe someone here would know exactly what gasoline carburetor was originally on the lift truck. Maybe you have this model truck, and could tell me what carburetor brand and model number you have??? Or????
Thanks in advance.
  • Posted 19 Jul 2020 02:51
  • By 55razor
  • joined 19 Jul'20 - 1 message
  • Michigan, United States
Ray
