BT Rolatruc RRB2 Reach truck 2008 display fault
Battery gauge doesn't work only the 2 red dots in between the time light up. It was intermittent at first now it is all the time. i have interchanged the display and A5 card with another truck and have replace wiring harness's and checked continuity from diplay back to A5 card. Display still doesn't work. Any help would be appriciated. I have spoken to BT technical guy and he doesn't seem to know what it is either. So i am hoping someone on here has had the same problem.
  • Posted 26 Oct 2010 22:00
  • By Leon_W
  • Tyne & Wear, United Kingdom
Like our mates told you, this problems generally comes from the three wires (think 70, 71, 72) of the charge battery level. If battery and wires is OK, replace A5 card
I found one case on a rrB6 series 16, that was neccesary to replace A5 logic card. Its very important the good state and tighten of negative thick wire that comes from batery to inverters. It's works like a shunt wire.
If you need any information, just ask for it.
Regards
  • Posted 27 Oct 2010 09:17
  • Modified 27 Oct 2010 09:28 by poster
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Hi BobbyT, when these wires are missing or damaged the battery gauge flashes. But on my truck i haven't got anything at all working the clock is off aswell.
  • Posted 27 Oct 2010 07:42
  • By Leon_W
Hi Leon, check the battery connector socket auxciliary connectors and wiring, these feed voltage and current from the battery for the A5, which in turn displays battery status on the dash. Guarantee it will be your problem, I have even seen that fault when the socket is not pushed fully home.............well I might be wrong but there is a pretty good chance this is the problem. cheers bobby
  • Posted 27 Oct 2010 01:48
  • By BobbyT
  • joined 25 Dec'08 - 31 messages
  • Wilts, United Kingdom
Maxlion ESD15M
JLG G12-55A
VETTER Forks, Inc.
Maxlion ESD15M
JLG G12-55A
