BT eror CODE C2
hi my guy i have problem
i have BT electronic forklift
eror code C2
plese help me
  • Posted 8 Jul 2011 21:39
  • By songyot_v
  • joined 8 Jul'11 - 103 messages
  • Thailand
thank you very much i will check
  • Posted 20 Jul 2011 20:37
  • By songyot_v
  • Thailand
working on a LSW20 pallet jack which the customer replaced the battery pack with new and after a couple on hours of use sage the battery drain out.Open the battery pack and found 4 12volt batteries in parallel 2 of the batteries after charge where 10.5volts and the other two 11.50volts/.Check for ground or shorts nothing only high reading was the upper contactor coil 59ohms???and the bottom one of 29ohms.
Your suggestion will be most appreciated.!!!
  • Posted 10 Jul 2011 02:40
  • By LOGIC
  • joined 6 Dec'08 - 70 messages
The simple things in Life are the greatest rewards!
From the error code I get the feeling its a BT / Cesab AC electric counter balance.
If it is one of those then C2 is an unused code & just something to ignore, its always the same when the Italians do the electrics.
  • Posted 9 Jul 2011 07:58
  • By Forkingabout
  • england, United Kingdom
Hi Mate
More information would be helpful. For example model and serial number.
  • Posted 9 Jul 2011 00:53
  • By elektrodrive
enquiries@elektrodrive.co.uk
