Blowing limiter fuse
We have 2 Raymond double walkies that started blowing the ANN-250 fuses. Usually it's when they get stuck in a pallet or when fully loaded going up a ramp. The problem use to be once a month, now it seems to happen weekly.
We have a 3rd machine that doesn't seem to ever blow fuses. All machines were purchased new in 2007.
any ideas?
Thanks!
  • Posted 15 Apr 2014 00:11
  • By bryan_w
  • joined 15 Apr'14 - 1 message
  • Utah, United States
How many hours on those?
Yes a bad battery will cause heat buildup, blown fuse. Are your SB connector pins soldered in? If you changed them, they must be soldered as heat will build up and fuses will blow. On any AC drive machines, the crimps on any cables need solder, or factory replacement type ones.
  • Posted 18 Apr 2014 09:31
  • By EasiTek
what does the battery read "at rest" vs what does the battery read under hydraulic stall < 3 seconds time.
10% or more drop in voltage = bad battery
  • Posted 15 Apr 2014 20:14
UN Forklift FBR25NQC3
UN Forklift FD30T-NJM1
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
CEO, Robust.AI
