Battery problems
I have caterpillar E6000 electric forklift, the battery is fully charged, turning the key off and on ,the bars on the battery level will drop, some times all the way down to 3 bars then dead, turn the switch off and on again and it might go back up might not, plug the battery into another forklift and its completely charged, but the forklift will quit moving when the dash says it's dead, even though the battery is charged. Any help appreciated.
  • Posted 19 Sep 2018 11:45
  • By rockhardhoosier
  • joined 10 Aug'18 - 5 messages
  • Indiana, United States
hi max_h
forum constraints do not allow email addresses inside the posts
you can add it in your forum profile in the signature area if you like and it will show up at the bottom of your posts or you can click on my name or look at my posts and get my email and send me one
would prefer posting a new thread here though and dealing with it in the forum so others can learn from it hopefully ;o)
But to address your code 47
basically you probably have a bad connection at the controller for your pump controller (the one on the right hand side), check the cable terminals, make sure none are burnt, and are all tight. Pay close attention to the post on the controller when you check the tightness, if the post moves or turns at all then it is more than likely broken off from it's solder point on the conductor plate it is soldered to. If this is the case then you will need a new or reman controller, these are cold soldered to the plates and cannot be repaired in the field.
  • Posted 19 Apr 2019 03:27
  • Modified 19 Apr 2019 03:28 by poster
hey swoop, I've seen you answers a lot, looks like you a guy with experience, I got this E6000 CAT with a code 47, any help here? thanks in advance, [email address removed]
You can reply there if you want.
  • Posted 18 Apr 2019 22:15
  • By max_h
  • joined 28 Sep'17 - 13 messages
Having same problem,,did you ever figure it out
  • Posted 25 Oct 2018 06:29
  • By Onearmsteve
  • joined 25 Oct'18 - 1 message
Thanks, I will start there
  • Posted 23 Sep 2018 02:49
check your connections to the display, check your connections to ground, Where your battery cables connect to the truck system check and make sure they are tight. Locate your logic card and pull each connector and inspect and replug back in and make sure the plugs insert fully and lock in.
Sounds like you have a bad connection somewhere.
  • Posted 23 Sep 2018 02:36
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
SMV (Konecranes) 4632CC5
TCM FHD105Z
Chandler, United States
Philadephia, PA, United States
