Battery Latching Problem
RRE200CC S/N : 6289023
Manual says to lock in battery... you retract the reach carriage till it stops.... then let go of the button and then pull the button a second time. A loud clunk should be heard, indicating the latch dog has latched around the release rod.
However, sometimes it takes 15 or 20 "second pulls" on the retract button to achieve this ??
  • Posted 30 Aug 2014 01:02
  • By UncleSi
  • joined 12 Feb'13 - 135 messages
  • Manitoba, Canada
Hello Forkingabout, i can see your help full reply on many posts, i have RRE250E and one of them is out of order because off faulty MCU since 2014 (cannot order parts due to some issues) took MCU and LID from another machine (operational) and install in down machine but this one showing error code 1:516, found one CAN connector damaged on MCU the connector can lock properly but some pins 22, 23, 141 and 91.1 are loos/damage,
appreciate if you can guide me :)
  • Posted 14 Jun 2018 22:25
  • By qasim_a
  • joined 25 Sep'14 - 40 messages
  • Sindh, Pakistan
Easy fix aint they.
  • Posted 30 Aug 2014 04:17
  • By Forkingabout
  • england, United Kingdom
Thanks man !!
Once again you are bang on the money !!
I've adjusted the eccentric, lubed things up here and there and she's all good !!
  • Posted 30 Aug 2014 04:07
  • By UncleSi
  • Manitoba, Canada
The battery bed catch will want adjusting.
There is an eccentric cam on the catch, simply adjusting the cam will fix the issue.
It may take a few goes at getting it right if this is the first time you have adjusted one.
  • Posted 30 Aug 2014 02:06
  • By Forkingabout
GemOne
