Baker / Otis FMD020
I recently aquired an FMD 020 which runs and lifts great BUT I will need to do some brake work to make it safe.
Anyone out there with owners / maintenance manuals schematics etc ??
  • Posted 5 Jan 2011 00:31
  • By ballvalve
  • joined 5 Jan'11 - 2 messages
  • New Brunswick, Canada
Thanks mate.
As we get it apart, I may be in toouch with ????, if not you are my go to on parts! BTW I understand, "slam-it", not my first 'antique' re-build...!
Cheers!
  • Posted 6 Jan 2011 23:34
  • By ballvalve
I have parts, service manuals and parts for the truck.
In order to access the brakes there is cover on each drive hub held on by 4 bolts. Remove the cover, remove the cotter pin holding the axle nut in place and then remove the axle nut. Once the nut is removed go to the opposite side off the truck and slam (and I do mean slam) against the inside of the tire with a solid bar about 3" in diameter and about 5' long. Turn the tire and continue slamming. The hub/tire/brake drum assembly will pop off.
  • Posted 5 Jan 2011 22:34
  • By duodeluxe
  • United States
duodeluxe
Taylor T520S
Manitou M50-4
Taylor T520S
Manitou M50-4
