Bad ring gear
I know this thing is really old but it comes in handy. Recently it's been grinding when engaging the starter and it's become a pain to start. I'm having the starter rebuilt but the ring gear is pretty bad too. I haven't had any luck figuring out what engine is in it. The tag on the engine says "F135 8008 3312" and the tag on the forklift says model LC52LT-2024. Serial AJ-117812. I talked to Yale but I never heard back from them. I'd like to order parts but I'm at a standstill. If anyone could help me out it would be greatly appreciated.
  • Posted 3 Feb 2022 14:59
  • Modified 4 Feb 2022 10:39 by poster
  • By Tyler_Behrens
  • joined 3 Feb'22 - 1 message
  • Iowa, United States
Its a 4 cylinder flat head engine? I did some research and the Continental F135 looks to be a lower displacement version of the ever popular F163 engine. Chances are its a press on ring gear. As an engine begins to get tired, the flywheel tends to stop in the same spot everytime. If you spun the flywheel 360 degrees with the starter off you will probbly find the rest of the flywheel looks ok. If you are unable to find the correct parts, you might consider pulling the flywheel, marking the current location of the worn area, knock the ring gear off the flywheel and reinstall it in a fresh area where it tends to stop. Much better would be to locate a new part. Good luck-
  • Posted 4 Feb 2022 12:40
  • Modified 4 Feb 2022 12:41 by poster
  • By ForklifttSteve
  • joined 13 Nov'19 - 30 messages
  • Mississippi, United States
Steve Pierce
Coast Equipment Services
SMV (Konecranes) 4531CC5
Maxlion FD30
VETTER Industrie GmbH
