alternate oils to Clark 2776326? (for TA16 transaxle)
salvaged a old Clark, actually came out pretty nice- brakes were weak, of course had to pull axles, dump a gallon or two of trans oil to pull hubs... oil was red, expect someone dumped dextron in it. it runs/pulls, but when cold is sluggish going into gear, know it had been that way for years according to guys who had used it.
Brake parts hopefully will be here tomorrow, and hopefully can find a proper oil locally- hoping someones had good results in a off the shelf oil from tractor supply or somewhere similar- do see the TA18 used different oils than other common Clark transaxles.
  • Posted 3 Oct 2018 12:43
  • By tc429
  • joined 3 Oct'18 - 10 messages
confidence: that feeling you have right before you realize the mess you got yourself into...
thank you- will change it to that, tractor supply has it :)
  • Posted 5 Oct 2018 08:18
  • By tc429
The trans in those old Clarks were sluggish when first started. Most operators got used to that. You can universal tractor fluid in the transmission and axle if the Clark oil is not available.
  • Posted 5 Oct 2018 06:20
  • By tom_p
  • Alberta, Canada
Terberg RT223
Mitsubishi FGE35AT
Chandler, United States
Philadephia, PA, United States
Terberg RT223
Mitsubishi FGE35AT
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Terberg RT223
Mitsubishi FGE35AT
Noblelift
