aisle master will not activate
I have an aisle master 44se. Key switch turns on as normal. When you press accelerator pedal nothing happens. No hydraulic,steering or travel. Checked fuses,seat switch directional switch. Checked switch in pedal. Checked relays.
  • Posted 9 Nov 2019 03:40
  • By hyster123
  • joined 23 Mar'19 - 9 messages
dave
You could have a faulty accelerator, when you turn the key on you should get power to the main controller terminal 1 and the aux contactor coil to power the DC/DC convertor. Once the controller see power it will give a supply to the main contactor. Once the main contactor is energised you need a feed from the seat switch. The hydraulics won't work until you de-press the accelerator. All of the can be checked using the curtis handset.
  • Posted 19 Nov 2019 18:59
  • By heightlift
  • joined 19 Sep'12 - 139 messages
  • North, United Kingdom
did you check seat switch
  • Posted 17 Nov 2019 03:40
  • By stackerhacker
  • joined 2 Mar'18 - 87 messages
  • glasgow, United Kingdom
Connected hand set. No active or stored faults. Main contactor pulls in and holds. Voltage checks at battery volts through contacts.
  • Posted 14 Nov 2019 06:57
  • By hyster123
dave
You will need to connect a curtis handset to see what is happening. Wiring diagram is in the back of the operators manual. The line contactor has to close before anything will work. Sometime the line contactor will come in the drop out. This usually indicates some dirt on the contact tips. Can happen after blowing off excess dust with an airline.
  • Posted 14 Nov 2019 03:43
  • By heightlift
