Adjusting idling speed / neutral gear at a Linde H30T Year 1994
Hello everybody,
The problem is that the forklift is traveling as soon as the handbrake is being released although no pedal is being pressed. I think that it is an adjustment problem on level of the hydrostatic drive. I found three all together 3 adjustment screws market on the following pictures with A, B, C.
(3 x w) bacoclean.be/public/Linde/
Copy and paste the url to see the pictures.
Can somebody tell me if the idling speed can be adjusted with one of them?
  • Posted 2 Mar 2012 04:07
  • By PP02
  • joined 3 Feb'12 - 1 message
  • Liège, Belgium
pkarmouze(at)gmail.com
Pull the floorboard up and take off the cover to the pedal linkage. The rod to the pedals can shift. loosen the 10mm bolt that holds the clamp that holds the rod in place and tap the rod in till its even.Thewir is no code or anything that comes up for this.Hope this helps
  • Posted 15 May 2015 10:55
  • By edward_m
  • joined 11 May'15 - 111 messages
Hi i can not view your pictures it sounds like your wheel begin valve is set up incorrectly, what is the serial number of your truck?
  • Posted 9 Mar 2012 23:44
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Zhejiang UN Forklift Co., Ltd
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Chandler, United States
Philadephia, PA, United States
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
