A stupid question
I have recently acquired a Komatsu FG-35-1 forklift with a Nissan gas engine at an auction. I need to make a few repairs and I need the model and serial number of the engine. I have looked everywhere. Where is the plate with the engine information located? Any help appreciated.
  • Posted 22 Nov 2007 08:55
  • By Riley
  • joined 22 Nov'07 - 5 messages
  • Alberta, Canada
thanks for the info,took pump off and internal splines on hub driving the pump are chewed out,looking for part this afternoon....
  • Posted 5 Dec 2008 07:34
  • By vernon
  • joined 1 Nov'08 - 2 messages
Just an FYI.
If I remember that truck right it has support bars that bolt lengthwise to the engine and trans. We have seen them come loose and the engine and trans separate. Basically the engine tilts downward fan first. They wiped out starters / ring gears in no time.
  • Posted 22 Nov 2008 21:17
  • By ExWrench
  • joined 22 Nov'08 - 2 messages
  • New Jersey, United States
riley,i have a FG-35-1... it has the nissan motor,hoeever my hyd pump is giving greive,do you have any parts for it,thanks,vernon in alberta...780 386 3979 ser no 60189 on the truck
  • Posted 1 Nov 2008 06:22
  • By vernon
Riley
Sorry for the delay in response.
The C indicates clutch type manual transmission, which is what our records indicate how the truck was built - along with the engine model I previously stated. If it does not have this engine in it, then it is possible someone swapped the engine out with something else.
What do you need the engine model and s/n for? Ar eyou looking for some part in particular?
  • Posted 3 Dec 2007 07:05
  • Modified 3 Dec 2007 07:07 by poster
  • By Jeff
  • joined 8 Feb'07 - 61 messages
There is nothing worse than a sharp image of a fuzzy concept.
-Ansel Adams
Maybe it's P40 Nissan engine. Try this :www dot cd-auto dot ru. They have engine manuals for fg35-1 forklifts. It's in russian off course, but you can try to e-mail them and ask wether the manuals are in english or not
  • Posted 24 Nov 2007 16:01
  • Modified 24 Nov 2007 16:04 by poster
  • By Agoenk
  • joined 24 Nov'07 - 6 messages
  • DKI Jakarta, Indonesia
Jeff....My model number is an FG-35-1. There is no "C" in the model. The serial number is as you stated 60110. Does this make a difference? Thanks for all your help. Much appreciated!
  • Posted 24 Nov 2007 10:33
  • By Riley
  • Alberta, Canada
I appreciate all the advice but I checked all around the distributor and could find no sign of any serial number or engine model number. I have searched from one end to the other. I'm stumped.
  • Posted 24 Nov 2007 10:19
  • By Riley
  • Alberta, Canada
Thanks for the info. Much appreciated. I'll have another look and see what I can find. Thanks again.
  • Posted 23 Nov 2007 06:40
  • By Riley
  • Alberta, Canada
Hello Riley,
FG35C-1 #60110 was shipped to Canada in 1975 with Nissan PPU240 Engine.
On most Nissan engines there is a flat surface located somewhere near where the distributor goes into the engine block where Nissan stamps the Engine Model and S/N.
FYI, the Komatsu Parts Book No. for this engine is PPU240-PE4 and although not normally stocked due to the age of the truck is still available from Komatsu. Contact your local Komatsu Forklift dealer by using the dealer locator at www dot kfiusa dot com
  • Posted 22 Nov 2007 22:46
  • Modified 22 Nov 2007 23:20 by poster
  • By Jeff
-Ansel Adams
Its a 6 cylinder gasoline powered Nissan Engine. The forklift model number is a Komatsu FG-35-1. S/N 60110
Hope this helps. Thanks.
  • Posted 22 Nov 2007 16:45
  • By Riley
  • Alberta, Canada
Is this a 4 or 6 cylinder? Also, is that the correct model number? -1 sounds like an old truck.
  • Posted 22 Nov 2007 16:05
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
probably a nissan H20 engine as fitted to petrol cabstars hope this helps
  • Posted 22 Nov 2007 10:10
  • By andrew_k
  • joined 17 Mar'07 - 339 messages
  • England, United Kingdom
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Maxlion R2B25LI
USD1
Maxlion R2B25LI
