0% battery
Hello colleagues, I have a problem with the newly charged battery, it marks 0% battery, and it does not let me raise it.
my question is if there are any parameters to set.?
Thanks in advance.
Greetings and Take good care of yourselves.
  • Posted 15 Oct 2021 00:37
  • By juanlao
  • joined 22 Jun'18 - 27 messages
  • islas baleares, Spain
Repair, not replace.
Gracias andrew_k, hace tiempo tuve el mismo problema con otra maquina igual, pero le intercambie las tarjetas del timon con otra y ambas funcionaron, pero este no ha sido el caso.
Thanks Andrew_k, some time ago I had the same problem with another similar machine, but I exchanged the rudder cards with another and both worked, but this has not been the case.
  • Posted 15 Oct 2021 17:14
  • By juanlao
Ive had this problem years ago, it was the pcb in the tiller head.
  • Posted 15 Oct 2021 08:04
  • By andrew_k
  • joined 17 Mar'07 - 339 messages
  • England, United Kingdom
Briefs United States
Lift Tek Elecar
Aichi RX07B
Maxlion FG25
Lift Tek Elecar
