FLEX 1500 for Reliability, Flexibility, and Profitability
- 3 Feb 2011 ( #499 )
Click to view larger image.
During the lifetime of your forklift there is a high chance of having an accident.
Many forklift accidents are related to tip-over.
The Flex 1500 has been developed to help increase the level of safety for workers operating lifting equipments in warehouses, manufacturing plants, or other similar environments. This system helps to protect your equipment against overload or abusive utilisation.
The Flex 1500 provides the only real safety device to reduce tip-over accidents on the following two very important factors:
LEAVER EFFECT: Lower weight value, when the load is placed toward the mast of the forklift, and higher weight value, when the load is placed toward the tip of the forks.
HEIGHT EFFECT: Lower weight value, when the load is located closer to the ground level, and higher weight value when the load is located to the maximum height limit of the forklift.
STRENGTHS
    FLEX1500 Sensor - click to view larger image.
  • Provide two alarms to reduce overload and accident;
  • Respect in every point the safety specification of the forklift, for the weight at center load and for the different height capacities, for any kind of lifts;
  • Help the operator during the training process to understand the lever effect in consideration of the load placement on the platform;
  • Improve the put away for your warehouse;
  • Will not affect the structure of the lift;
FLEX1500 Indicator - click to view larger image.
FEATURES
  • Installed without lift modifications;
  • Calculated the weight in regard of the lever effect;
  • 2 Alarms to control the safety limits;
  • 4 different height capacities can be implemented;
  • Stabilisation delay programmable;
  • Zero tracking;
  • Return to zero protection
WHY SAFETY IS IMPORTANT?
  • Reduce absences
  • Excellent boost to the employee's morale.
  • Reduce business cost such as insurance premiums, and business disruptions.
For more product and company information contact:
Gary Saigh / Director
Flexco Industries Inc.
LaSalle, Quebec, Canada
Tel.: (514)935-2121
Fax: (514)935-1041
Email: gsaigh@flexcoindustries.com.
Web: www.flexcoindustries.com
Or, click to view the Flexco ShopFront
