Standard forks with modular integrated assistance systems from VETTER
- 18 Sep 2025 ( #1248 )
With the SmartFork Basic advantage package, fork manufacturer VETTER offers smart assistance systems for standard forks.
The SmartFork Basic package is a modular combination of the proven SmartFork components FrontCam and Laser in the fork tip and SideCam in the fork blade. The basis is formed by standard fork blades with dimensions of 100 x 45 x 1200 mm, made from specially developed high-performance steel. Thanks to special heat treatment, VETTER ensures optimal material tempering and thus maximum durability of the fork tines. The integrated camera and laser technology has proven industrial strength and is ideally suited for daily heavy-duty use.
Overview of the features of the individual SmartFork components:
  • SmartFork FrontCam: Clear view to the front when picking up loads – forklift drivers can spot people and obstacles early on
  • SmartFork SideCam: Easy targeting along the forks for precise insertion into pallet pockets.
  • SmartFork Laser: The green line laser helps forklift drivers to target goods precisely
Depending on the intended use, the SmartFork Basic can be individually combined with the individual components. For example, a pair of fork tines can be equipped with one of the three assistance systems or with a combination of a FrontCam or SideCam camera solution and the laser function.
Flexibility through modular combinations
The SmartFork Basic is complemented by practical accessories such as a 7-inch monitor, mast cable set, or radio set. The 7-inch monitor is only necessary for the camera assistance systems. For power and data transmission for the FrontCam and SideCam and their combinations with the laser assistance system, you can choose between Mast cable or radio set can be selected, while the laser can be powered by a battery set as a solo assistant.
Contact us for more information!
Get in touch with VETTER Industrie GmbH
+49 273... Show
Carl-Benz-Strasse 45
57299 Burbach
Germany
