Tackle the challenges of the paper industry with Bolzoni Group – Join us at MIAC 2024!
- 26 Sep 2024 ( #1198 )
5 min read
Bolzoni takes part to MIAC 2024 Exhibition to display its paper handling technologies at booth #A1.
Amid international competition and new consumer demands, the paper industry is looking at continuous technological advancements and innovative solutions to enhance production and handling operations. In line with the industry trends, Bolzoni Group is not only keeping pace but also thrives to develop dedicated solutions to meet the sector’s evolving needs.
Bolzoni Group is eager to highlight its latest technologies to support the paper and cardboard production and tissue paper converting at MIAC 2024, the premier international exhibition for the paper industry, taking place in Lucca, Tuscany, from October 9th to 11th.
Bolzoni Group is ready to welcome international experts from the paper industry at its booth #A1, to show how its technology and innovation can support forest products logistics throughout the converting process.
Thanks to its expertise, Bolzoni Group with its brand AURAMO is well known as an excellence in paper handling solutions. Over the years, working closely with the main paper companies, AURAMO has constantly improved and expanded its range of dedicated paper handling products, with focus on all paper handling requirements from paper mills, to port terminals and recycling centers.
Showcased Products:
Unleash efficiency with the AURAMO clamp: your tissue paper roll game-changer
Tissue paper rolls have a high value, are easily prone to damage and require the use of a specialized clamp to ensure safe and efficient handling.
The AURAMO AR-RT series clamps are designed to offer exceptional visibility, with a quick and safe 180-degree rotation, and user-friendly operation.
The lightweight design of the clamp allows for versatile rotation, enabling the handling of rolls both vertically and horizontally, with hydraulic cushioning at the vertical end position.
The AURAMO AR-RT model can handle large diameter tissue rolls, with capacities ranging from 1,500 kg to 6,000 kg (3,000 to 13,000 lbs.) and roll diameters up to 2,700 mm (106”) in the standard series.
Leveraging Bolzoni Group’s extensive experience in the paper industry, these clamps are designed with enhanced contact pads featuring rounded surfaces and corners, as well as wider and higher arms and pads to reduce surface pressure on soft tissue paper. The triple radius pads, with convex edges, prevent the pad edges from cutting into the paper, ensuring suitability for all types of tissue paper.
AURAMO bale clamp B-W model for waste paper handling
The AURAMO B-W model has a strong double T-profile frame and robust arms with gripping steel rods.
Collecting and transporting recycled wastepaper is one of the toughest applications in the forest products handling chain, generally harsher than any other bale handling operation, and forklift truck attachments often need increased protection against wear and tear.
The AURAMO B-W  model clamp is specifically designed for heavy-duty handling of waste paper bales, and it is widely employed in plastic and recycling materials handling as well.
With capacities ranging from 1.600 kg to 7.000 kg (3,500 Lbs. to 15,400 Lbs.) and with a wide choice of opening ranges, arm lengths and options.
Silver Line bale clamp LC-G model: durable and cost-effective
Commonly used for handling pulp bales in the paper industry, as well as bales of cotton, wool, tobacco, fabrics, and other baled materials, it boasts a robust design for heavy-duty applications.
At the MIAC exhibition, you can explore the Bolzoni LC-G Silver Line bale clamp, featuring robust, well-protected components designed to withstand wear and tear in demanding environments. This equipment is ideal for minimizing costs without compromising performance. High tensile aluminum profiles, reversible and interchangeable with wear-resistant plastic inserts, ensure long life and low lifetime costs.
In addition to its premium range of forklift truck attachments, Bolzoni is introducing the Silver Line range, designed for operators seeking extremely robust attachments capable of handling tough applications. This range offers reliable and cost-effective forklift truck attachments suitable for various industries, especially where easy-to-maintain equipment is essential.
BOLZONI Lift Table Model 1A: the versatile solution for the paper industry
The Bolzoni Lift Table Model 1A enhances productivity in the paper processing industry. With a wide range of options like a roll-off stop, roller conveyor, and circular turntable, it can be customized to meet specific needs.
At MIAC 2024, we are thrilled to present our Bolzoni lift tables, showcasing significant benefits for the paper processing industry. These lift tables are essential tools in this sector, facilitating the handling, ensuring smooth transitions between different stages of production. This not only enhances efficiency but also minimizes the risk of injury, creating a safer workplace for operators.
Our range of lift tables is particularly suited for industrial applications. The Bolzoni scissor lift table model 1A, for instance, is widely used as a workstation in various production processes, including those in the mechanical, woodworking, and engineering industries. Designed for heavy-duty applications, this versatile model is ideal for tasks such as machine feeding and stacking, making it an asset across different industrial settings.
The Bolzoni scissor lift table model 1A is engineered to handle partially concentrated loads with capacities ranging from 1,000 to 7,000 kg (2,000 Lbs. to 15,500 Lbs.). It features a smooth top platform, self-lubricating bushings on pivot points, and can perform up to 30 cycles per hour in a single shift.
Electric-Driven Innovations for the Paper Industry
Just like in other industries, companies in the paper sector are increasingly interested in automation, which often leads to the search for electric-driven solutions.
In addition to the displayed attachments at the exhibition, the Bolzoni Group is recognized as a leading provider of electric-driven attachments for applications on AGVs. Closely cooperating with the major AGV manufacturers, Bolzoni has developed a series of attachments featuring specialized features, to meet AGV applications. With a dedicated Technical and Sales Team, Bolzoni Group is able to support the AGV provider cooperating on several levels, or with the supply of plug-and-play solutions: from the co-design to the installation and set up of the attachment in place.
For more information on Paper Handling Solutions, get in touch with the Bolzoni Group, get in touch and ask for our references on the range, or to organize a demo unit at your facilities.
Visit the dedicated Paper Handling Solutions section on our web site and contact us, or contact the nearest BOLZONI, AURAMO and MEYER representative.
Bolzoni, Auramo and Meyer are Bolzoni Group brands.
The Bolzoni Group is a market leader in the production of forklift truck attachments, forks, and lift tables. The company has manufacturing plants in Italy, Germany, Finland, America, and China and through its network of direct branches and independent dealers covering all continents it is able to satisfy all market requirements.
Bolzoni SpA (Group HQ)
+39 052... Show
Via I Maggio, 103
I-29027 Casoni di Podenzano,
PC, Italy
