Embrace the Industry 4.0 philosophy with Bolzoni Group Easy-Connect Solutions Scroll down for video
- 15 Feb 2024 ( #1166 )
5 min read
Intelligent Paper Roll Clamp CTX G3 with
E-connect technologies, to prevent paper roll out-of-roundness and to grant damage-free valuable paper roll handling.
Intelligent Paper Roll Clamp CTX G3 with E-connect technologies, to prevent paper roll out-of-roundness and to grant damage-free valuable paper roll handling.
Companies involved in the world of material handling are increasingly integrating intelligent technologies and automated systems into their processes to match evolving challenges.
These advanced technologies, such as innovative forks and electric-driven attachments, enable the companies to greatly improve efficiency and lead to self-optimization of material handling process, including maximizing warehouse space and reducing handling times.
Bolzoni Group has developed a bespoke innovative solution range tailored to suit the client’s requirements: Easy-Connect.
The range is based on cutting-edge connectivity which offers a wide range of advanced technologies whilst supplying useful smart logistics solutions.
The Easy-Connect Product range - thanks to advanced sensors, lasers, cameras, embedded software and robotics - meets innovative and high-quality material handling expectations, especially for companies embracing the Industry 4.0 philosophy.
In addition to the benefits of data collection and analysis through the system, our equipment enables better decision-making, increasing and improving safety and efficiency.
Damage reduction with Bolzoni Easy-FORK Vision System sensor
Bolzoni Easy-FORK high-quality camera with LED lights completely integrated in the fork tip.
In case of limited operator visibility, especially when handling pallets on high shelves, Easy-FORK Vision Systems enhance the view and safe handling in storage areas.
The Easy-FORK Vision System includes a whole range of smart forks equipped with side, tip or front camera with line laser that allow full frontal visibility even with the load on the forks.
The Easy-FORK Vision System with front camera and line laser is particularly useful in case of low light environment, as the system integrates on the screen a fixed reference, aligned to the fork's tip, providing a landmark during the picking up phase.
The well-protected laser projects a linear blade with a 90-degree angle which is aligned with the fork tips and guarantees the correct reference when loading pallets.
Thanks to the camera position, the driver has a clear view on both fork tips, with a horizontal 120° view angle and a vertical 52° view angle. The color camera is equipped with 6 IR LED and high-resolution images are displayed on a 7-inch monitor installed inside the driver cabin.
Intelligent pressure control systems with Bolzoni Easy-Connect Solutions
When it comes to handling white goods that are prone to damage and with a high unit value it is highly recommended to equip the forklift with damage prevention technological solutions.
Among the Easy-Connect solutions, the Easy-FORCE-C is a semi-automatic force control system, useful for White Goods handling. Through a touch screen, the driver selects the handling load category, type and configuration, and the pressure parameters are automatically set into the clamp to generate the correct clamping force. Moreover thanks to the GPS geolocalization and data collection, fleet managers can analyze handling data later, remotely, via a dedicated portal for managers.
Easy-MOVE clamps are ex-factory preset with load and pressure parameters agreed with the customer. Or simply switch it to single pressure manual mode.
Designed for home and appliance handling with a high level of product differentiation, the Easy-MOVE carton clamp is a laser sensor system with the most advanced technology in sensors and clamping force control.
This completely automatic system is driven by laser sensors and by an electric microcontroller that can detect load dimensions and input the correct clamping pressure through a proportional pressure relief valve. In fact, the change in clamping force is a key driver for load damage prevention.
In cases of paper roll handling, Easy-Connect technologies help to prevent paper roll out-of-roundness and to grant damage-free valuable paper roll handling. The Intelligent Paper Roll Clamp CTX G3, with a microprocessor control system and sensors, automatically uses the optimized, lowest possible clamping force for all handling situations and paper grades.
Easy-Connect Solutions for AGV applications
Thanks to our long cooperation with the main players in the AGV sector, Bolzoni Group designs and produces customized AGV attachments. The Bolzoni AGV range includes both hydraulic and electric-driven attachments, equipped with a full set of sensors, as per customer specifications, or with an agreed pre-setting to accept the customer’s own sensors and cabling.
Bolzoni can offer different levels of solutions:
  • Standard equipment with sensors and cabling pre-set
  • Plug-and-play solutions with complete fitment of sensors and cabling
  • Customized solutions in co-design with AGV producer
Bolzoni Group has a dedicated Technical and Sales Team to support AGV (automated guided vehicles) Manufacturers. The implementation of each attachment is the result of a co-design between our customers and our Project Team. Following specifications and instructions on the electronics to be fitted on the attachment, we design, manufacture, deliver and install the attachment.
The attachment can be delivered as a plug-and-play solution, meaning we take care of the engineering, purchasing and manufacturing of all components. Furthermore, delivery includes the parameterization of the attachment on the AGV.
Bolzoni fully electric fork positioner: more precise in positioning
Bolzoni 360-degree support on AGV attachment implementation includes co-design on the project and final installation.
Included in the Easy-Connect Range, the fully electric driven fork positioner is fitted with an electric actuator able to precisely position the forks according to the handling load. A full set of sensors installed on the attachment supports the AGV to accomplish the different tasks in the manufacturing and warehousing processes.
Come and meet our Sales Engineers at LogiMAT, in Stuttgart, 19-21 March
– Hall 10 Stand F65 - and visit the Bolzoni Lift Table space Hall 7 Stand A21.
For more information on Intelligent Solutions visit our website; get in touch with the Bolzoni Group Specialist to ask for our references on Easy-Connect Handling Solutions, or to organize a demo unit at your facilities; or contact the nearest BOLZONI, AURAMO and MEYER representative.
Bolzoni, Auramo and Meyer are Bolzoni Group brands.
The Bolzoni Group is a market leader in the production of forklift truck attachments, forks and lift tables. The company has manufacturing plants in Italy, Germany, Finland, America and China and through its network of direct branches and independent dealers covering all continents it is able to satisfy all market requirements.
Bolzoni SpA (Group HQ)
+39 052... Show
Via I Maggio, 103
I-29027 Casoni di Podenzano,
PC, Italy
