Delta Launches MOOVair 1 kW Wireless Charging System for Industrial E-Vehicles Scroll down for video
- 26 May 2022 ( #1078 )
Delta, a global provider of power and thermal management solutions, introduces the brand new Wireless Charging System MOOVair Series - an innovative industrial charging solution for automated electric-driven vehicles. The newly presented MOOVair 1 kW Wireless Charging System offers up to 1 kW contactless, high efficient charging for all types of 24 V / 48 V batteries, and is suitable for automated e-vehicles that require a frequent battery charge.
The 1 kW Wireless Charging System features a 1,000 W output, peak efficiency of 93%, and power transmitted over a gap of up to 20 mm. It is made of two parts: a transmitter connected to the AC supply as primary charging unit and an onboard charging unit connected to the battery. The onboard charging unit is available in versions suitable for 24 V or 48 V batteries, and multiple onboard units of either variant can share one transmitter pad saving space and cost. The onboard charging unit is compact (168 x 82 x 28 mm) and lightweight (1.5 kg, onboard charging pad included), making it simple to place inside even small e-vehicles. With the charging pads protected against water and dust to IP65, and a robust design for shock and vibration, the MOOVair Series has reliable performance even in harsh industrial environments.
Another highlighted feature of the MOOVair Series either is charging by inbuilt profiles covering a range of batteries (bespoke profiles available on request) or by CAN bus control. With no cable, no connector wear, no maintenance downtime, smart communication and remote management, the 1 kW Wireless Charging System MOOVair truly realizes smart, automatic 24/7 operation for industrial electric vehicles manufacturers (AGV, AMR…), battery manufacturers, system integrators, industrial automation planners and solution providers.
Learn more about the innovative, smart charging solution here.
Delta MOOVair 1 kW Wireless Charging System for AGVs, AMRs and Industrial e-Vehicles
Contact us for more information:
Get in touch with Delta Electronics, Inc
+49 764... Show
Tscheulinstrasse 21,
79331 Teningen,
Germany
