A.T.I.B.® NEW HYDRAULIC TELESCOPIC FORKS
- 28 Sep 2017 ( #840 )
NEW TELESCOPIC FORKS TYPE 61
With 45 years of experience on the forklift business as manufacture of hydraulic attachments, A.T.I.B.® has recently launched their NEW TELESCOPIC FORKS for reach trucks and counterbalanced forklift.
It's already known that telescopic forks speed up loading and unloading time, cut internal transport costs in half, improve space utilization and reduce damages to both goods and pallets.
Improvements done by A.T.I.B.® technical department have obviously taken into consideration all those aspect and have been focused on the following elements:
STRENGTH
A.T.I.B.® TELESCOPIC FORKS have higher push and pull strength by the use of a single cylinder on each fork; in addition to the normal 25% time saving by one sided loading or unloading, this allows to the forklift driver the possibility to extend or retract forks with the load, saving an extra 10% time for the same operation.
THE SINGLE CYLINDER SYSTEM
DEPTH
The NEW TELESCOPIC FORKS have been realised with an extra 6% stroke, offering the possibility to go deeper and load or unload trucks and racks with much safer operations.
IMPROVED DEPTH OF FORKS
LIGHTNESS
A.T.I.B.® TELESCOPIC FORKS have been realised using smaller forks section in order to save weight and increase the residual capacity of the forklift, in particular when forks are extended.
CAPACITY
Despite the use of smaller forks section, The NEW TELESCOPIC FORKS are made by special steel and manufacturing process giving as result an increase of 20% of their capacity, compared to the previous ones.
RESIDUAL CAPACITY SCHEME
DURABILITY
A.T.I.B.® TELESCOPIC FORKS have new fork pockets shape with bottom plates of high strength steel, increasing the life of the forks; the new shape with a wedge tip helps the driver during forking operation and reduces significantly damages to pallets and goods.
THE NEW EXTENSIONS SHAPE
TELESCOPIC FORKS WITH BOLT ON LOAD BACKREST
STANDARDS
On all NEW TELESCOPIC FORKS (link 2) is installed by series a flow divider for a synchronised movement of the forks and a pallet stop; in option A.T.I.B.® can offer bolt on load backrest of various heights and widths, as per customer's needs.
COSTS
As result of all development activities, A.T.I.B.® has achieved also one of the most important targets in a period of strong competitiveness: the cost reduction. Keeping the quality standards which are a must for this independent Italian manufacturer, the NEW TELESCOPIC FORKS are now offered at very competitive prices.
FLEXIBILITY
A.T.I.B.® TELESCOPIC FORKS are now available with mounting class ISO Fem 2 and 3; standard lengths are available from stock, special lengths can be delivered within 4 weeks. Customised solutions are also offered under request, as normally done for all A.T.I.B.® products.
Don't miss this opportunity to test the A.T.I.B.® NEW TELESCOPIC FORKS; please ask to your local sales representative for further information and follow us on LinkedIn.
A.T.I.B.® S.r.l.
Michele Triboldi
Sales & Marketing Director
Ph: +39 030 977 17 11
E: send an email
W: www.atib.com
