Enjoying the summer period in a calm and relaxed manner
- 6 Jul 2017 ( #828 )
The driver may might not be aware that the forks protrude through the rear side of the pallet. It can lead to costly product and pallet damage and injury to other personnel
While your permanent employees stroll along the boulevards of popular holiday resorts or enjoy a refreshing drink at the poolside, your factory may be run by less experienced and less skilled holiday workers. A scary thought!
Novice workers with little experience and minimum skills certainly set the stage for trouble and delays.
The stakes are high, especially when working with heavy machinery like forklift trucks. Less experienced lift truck drivers may not be accustomed to your forklift, (equipment), so, this can increase the odds for product and pallet damage, resulting in unnecessary costs. Thorough training would be the ideal solution, but in the real world, it's simply not always possible to get temporary employees up to speed in time for the holiday break.
Relax, a simple solution is available!
If your application requires two-way pallet handling or differing load lengths and you are concerned about product damage, relax, a simple solution is available. Extendable hydraulic forks allow the operator to adjust the tines to the correct length at the touch of a lever and without getting off the truck. Even though your permanent employee s may know all the tricks to handling various pallet sizes safely and efficiently, this solution can help them as well. Oversized forks often cause product damage and hinder movement. Adjustable forks solve these issues.
Damage caused because the lift truck forks protrude at the rear of the forklift
Avoid damaged pallets and goods
Extendable lift truck forks, manual extendable and hydraulic ones, can help avoid the problem shown here. Extendable forks add value to forklift truck in the form of added versatility which results in cost-savings. And in the case of a less experienced lift truck driver, these innovative forks can help you avoid the unnecessary costs from product damage The correct fork length for the load is always available.
Double-deep stacking, one sided loading and double pallet transport
Not only do hydraulic extension forks prevent damage. Other common applications include converting conventional lift trucks into single or double-deep reach trucks in order to help improve space utilization and storage density. They are also used for loading and unloading trailers or rail cars from just one side in order to improve safety while saving time, fuel and labour costs. Furthermore, they can be used to transport two loads at a time cutting internal transport costs up to 50%.
An alternative for limited budgets
The cheaper manual extendable forks are for companies with less frequent need for variable fork length. To extend the lift truck tines the lift truck driver simply releases a fingertip locking lever at the fork tip and extends the outer fork manually. The forks are always there when needed!
Hopefully, the tips and tricks in this article will help you through the holiday period in a calm and relaxed manner. We wish you and your family a happy and safe holiday!
Want to know more? Visit www.meijer-handling-solutions.com for a complete overview of our innovative logistic solutions.
Meijer Handling Solutions
Customer Service
P: +31 (0) 518 49 29 29
E: send an email
W: www.meijer-handling-solutions.com
About Meijer
Meijer Handling Solutions is based in The Netherlands with a wholly owned subsidiary in the USA and distributors in more than 60 countries worldwide. The company leads the world market as the largest producer of hydraulic lift truck forks more commonly known as "KOOI-REACHFORKS®" however, MHS also produces a wide range of other innovative material handling solutions including; Height Shift Systems, (vertical lift forks), telescopic Jib Crane attachments and booms as well as a complete range of pallet-less handling solutions such as ROLLERFORKS®, Stationary Pallet Changers and more, www.meijer-handling-solutions.com/products
