New EP AC Reach Trucks
- 16 Aug 2012 ( #578 )
EP Equipment is a professional manufacturer dedicated to materials handling equipment and mechanical components. EP has already built worldwide sales network in more than 40 countries and regions, and set up several branch companies in EUROPE, USA, CANADA, JAPAN and KOREA. In the past five years, with 50% growth every year, EP has become a global forklift manufacturer and intralogistics service provider. In the 2008 edition of famous Germany magazine "DHF Intralogistik", EP ranked 24th in the list of materials handling manufacturers all over the world.
Since our mission is to meet all the customers' needs in specialised markets, this season EP launches the new CQD series AC reach truck with competitive performance, superior quality and very attractive pricing. EP AC Reach Trucks have excellent accelerating, lifting and braking performance and have improved reliability and reduced maintenance requirements by using intelligence technology.
The special features of EP AC Reach Trucks are:
1. Drive motor
Advanced AC driving motor has high traction power and driving dynamics, even on uneven ground or on ramps.
2. AC Controller
  1. Advanced regenerative braking guarantees low-energy consumption and increases work efficiency.
  2. Efficient signal processing controller not only reduces the response time,but also improves battery life cycle.
  3. Since all the advanced configuration models have adopted AC motors, the trucks are more efficient and reliable.
  4. All models are equipped with an electric power steering system which greatly decreases steering action time and makes the operation much easier.
3. Hydraulic system
CQD16RVF
  1. The AC hydraulic motor provides stronger torque and ensures smoother and more reliable fork lifting and lowering.
  2. Advanced electro-magnetic steering valve allows operations like forward, backward, lifting, lowering, tilting and side-shifting to be completed by finger manipulation.
  3. Electric power steering system ensures smooth and precise steering function.
CQD16RV/CQD16RVH
  1. One-way speed valve plays a key role in ensuring the goods can be stably and safely lowered, protecting the load and assuring safe operation.
  2. The lifting and lowering speed can be manually adjusted, easily and reliably.
  3. Electric power steering system ensures smooth and precise steering functions.
4. Brake system
  1. Double brake system - Motor Magnetic brake and Hydraulic brake system - ensures rapid and short-distance braking.
  2. Electro-magnetic brake enables a more secure parking brake, even on an incline.
  3. Electro-magnetic brake, motor brake and hydraulic brake triple the safety, improving the product life.
5. Mast system
  1. Combined roller mast is made of high strength for low deformation.
  2. The cylinder is installed behind the mast, which provides improved visibility.
  3. Double "sliding wheel" mast suits for more applications, since its lowered mast height is extra-low.
6. Operability
  1. Advanced stepping motor improves the body turning and positioning accuracy and makes the body more flexible and suitable for small space.
  2. Control part has a compact structure, and its arrangement is ergonomic. So, the truck provides the operator with a large operating space.
  3. lThe design of the truck body is thoroughly tested to ensure the reliability and security of the truck structure, and also to widen the operator's field of vision.
  4. Battery locking mechanism allows the operator to control the battery change through the rod when the mast moves forward and backward, so the whole process is fast and convenient.
  5. Steering wheel can be adjusted for operator convenience.
  6. Camera option allows the operator to take goods more accurately and quickly.
7. Serviceability
  1. Top quality American AMP connectors prevent moisture and contaminants from interrupting truck operations in all environments. In addition, all the wires and cables are reliably protected and fixed, which greatly reduces potential electrical faults.
  2. Simple operation, reliable structure and easy access greatly reduce the truck maintenance time and cost.
  3. Hydraulic parts, pipes and seals are accurately arranged, which makes lifting stable and lowering smoother, while preserving the life of the seals.
  4. The digital display can show all the fault codes, assisting engineers to solve problems quickly.
  5. Contact details:
    EP EQUIPMENT CO., LTD.
    TEL: 86-571-28035657/28035633
    FAX: 86-571-28035665
    EMAIL: info@ep-ep.com
    Click here to visit our shopfront
