MODEX: Ragasco Composite LPG cylinders for Fork Lift Trucks
- 2 Feb 2012 ( #550 )
Ragasco is the world's leading developer and producer of advanced technology LPG composite cylinders which offer tremendous benefits to the material handling and logistics industry. Our composite lightweight LPG cylinders have numerous features that set them apart from traditional cylinders due to exceptional lightweight construction, transparent walls, extremely high pressure rating and ergonomic stylish looks. These are truly the LPG cylinders of the 21st century.
Ragasco through its state of the art fully automated facility has supplied over six million composite LPG cylinders worldwide since 2000 and has recently received Department of Transportation (USA) & Transport Canada (Canada) approvals for their LPG cylinders for Forklift Trucks (FLT). The cylinders are available in two sizes 10 kg (22 lbs) and 14 kg (31 lbs).
The major advantage of Ragasco composite is the cylinder's light weight which is 50% less than steel and 25% less than an aluminum cylinder. The largest cylinder has an ex-valve tare weight of only 7.5 kg (16.5 lbs) giving a maximum weight of 21.5 kg (47.3 lbs) when full. All cylinders have identical tare weight which equates to reduced risk of overfilling due to incorrect tare weight identification.
The low weight combined with an ergonomic design makes the cylinder very easy to lift and handle plus they are also stackable for trouble-free storage. The single-piece pressure vessel is a seamless construction for maximum safety. The all-composite cylinder is corrosion-free and has a clean inner liner surface assuring no contamination to the engine.
The FLT cylinders can be delivered with a wide range of colors and valves for liquid service including a US configured UL listed multifunction valve with service connector, pressure relief valve and stop-fill function for filling in the horizontal position.
Lightweight, Transparent & Safe
The unique lightweight three layer cylinder construction offers enormous advantages for use by all parties. With the cylinder's lightweight and ergonomic design your employees will find lifting the tank much easier and safer. They are easily portable and attractively designed,
The cylinders are transparent for visible gas level so there is no residual fuel being returned and as a result reducing your overall fuel cost. Ragasco's cylinders have unrivalled safety in both the short and long term, with no risk of explosion and no corrosion over time regardless of climate. Since the cylinders are explosion proof they provide unparalled employee and plant safety and your insurance cost may be significantly reduced.
Customer Loyalty
Introduce the Ragasco composite FLT cylinders to your customers and employees and they will never go back to metal cylinders. Be innovative and the first in your area with this unique product.
Come visit us at Modex Booth 5018, where we will showcase our composite lightweight LPG cylinders.
For more information visit Ragasco's website at www.ragasco.com or contact Ragasco at:
United States and Canada:
Bob Jones - North America Sales Manager
E-mail: bob@ragasco.com
Telephone: +1 561-254-8821
The rest of the world:
Morten Balle - Regional Sales Director
E-mail: mba@ragasco.com
Telephone: +34 699924048
