How advanced relay contact design transforms forklift reliability
Carlos Mendes -
Your Focus
- 20 Nov 2025 ( #1257 )
Relay contacts can determine whether your fleet runs smoothly
Carlos Mendes is a product manager for switching at Durakool, working closely with engineers and buyers to bridge the gap between application and specification.
Deep inside every forklift's electrical system, relay contacts no bigger than a pinhead determine whether your fleet operates smoothly or suffers costly downtime. While these microscopic interfaces might seem insignificant, they shoulder massive responsibilities - switching hundreds of amps, surviving thousands of cycles and maintaining reliability in environments that would challenge much larger components.
The reality is harsh: DC arcing doesn't naturally extinguish like AC current. When contacts separate under load, that persistent arc creates localised heating, material erosion and the ever-present threat of welding.
Add high inrush currents from DC motors, constant vibration and contamination from dust and moisture, and you have the perfect storm for premature relay failure.
Beyond the standard flat contact
Industry leaders are abandoning one-size-fits-all approaches in favour of purpose-built contact geometries. Each design philosophy tackles different challenges in the unforgiving world of industrial material handling.
Dome contacts concentrate pressure at a single point, penetrating surface films and oxides with authority. Their rounded profile minimises arcing during disconnection whilst reducing oxidation buildup through controlled over-travel. The trade-off? That concentrated pressure creates hotspots which are prone to welding under extreme loads. These contacts excel in high-current applications where switching frequency remains moderate - think main power contactors where reliability matters more than cycle count.
Crossbar designs take a different approach entirely. Their broad, stable surface distributes current and heat across a wider area, reducing contact resistance and improving thermal management. The crossing mechanism delivers a forceful wiping action that cleans debris from contact surfaces during each operation. However, this mechanical complexity introduces bounce during vibration, potentially causing erratic switching behaviour in mobile applications.
Bifurcated contacts split the difference, quite literally. By dividing contact points into multiple spring arms, they create redundant current paths whilst reducing bounce and improving arc dispersion. Each arm operates independently, so if one fails or develops poor contact, others maintain circuit integrity. The limitation? Unless heavily reinforced with materials like tungsten, they're typically not designed for the highest current levels.
Real-world performance under fire
Consider a case where a fleet manager struggled with premature relay failures in forklift attachments. The original specification called for standard mini-ISO 40A relays, but frequent contact welding was shutting down operations. The culprit? Inadequate or inexistent arc suppression under high inrush motor currents.
The solution involves upgrading to relays with magnetic blowout systems, essentially miniature arc chutes that stretch and extinguish arcs before they can damage contact surfaces. Same form factor, same mounting, dramatically improved reliability.
Another fleet discovered that thin plating on contact surfaces was creating weak points under stress. Surface layers were splitting away from the base material, creating air gaps and uneven pressure distribution. Upgrading to thick-layered plating with proper material selection eliminated welding issues and extended service life significantly.
The engineering edge
Advanced relay designs are addressing the fundamental failure modes that plague industrial applications. Arc suppression techniques including magnetic blowouts, sealed chambers with inert gas and permanent magnets, actively manage arc behaviour rather than simply hoping contacts can survive it. Anti-weld materials like tungsten alloys and silver tin indium oxide resist fusion under extreme conditions.
Self-cleaning contact geometries with sliding or wiping action maintain conductivity over thousands of cycles. Sealed enclosures prevent contamination whilst snap-action mechanisms ensure rapid engagement that minimises arcing time. These aren't theoretical improvements.  They are solutions that are already delivering measurable results in demanding applications.
The specification challenge
When evaluating forklift systems, dig deeper than surface-level ratings. Ask about contact geometry and why it was chosen. Understand the difference between rated capacity and real-world performance under your specific operating conditions. Question arc suppression methods, contact materials and expected mechanical life.
Most importantly, consider the total cost of ownership. A relay that costs twice as much but lasts five times longer while preventing unplanned downtime in an industry where every hour of operation matters, represents genuine value.
Also Read:
Manual or automated material handling: finding the right balance
Diana Davoyan
3 minute read
Manual or automated material handling: finding the right balance Your Focus - 6 Nov 2025 (#1255) Diana Davoyan is a marketing professional and copywriter in the global robotics sector, with extensive experience in industrial and warehouse robotics. Here she looks at striking the right balance between manual and automated MH operations.
How software platforms and AI are changing work for material handlers
Buddy Bockweg
4 minute read
How software platforms and AI are changing work for material handlers Your Focus - 23 Oct 2025 (#1253) Buddy Bockweg is the CEO and co-founder of Vsimple, the AI Operations Platform. Here he loosk at how sotfware platforms and AI are changing work for material handlers.
Murray Cox
2 minute read
VETTER Forks, Inc.
