EnerSys leads the industry in providing battery and charger solutions!
- 23 Mar 2006 ( #252 )
4 min read
EnerSys is the world's largest industrial battery company offering a broad line of batteries and chargers for electric lift trucks, ground support equipment, mining equipment and AGVs. We've been designing, testing, building and servicing batteries since 1888 to pack over a century of design innovation and commitment to quality into our Exide Ironclad and General Battery brand batteries and chargers.
Our newest product release, the Express Fast Charge System, allows you to keep your lift truck running over multiple shifts without changing the battery. The first part of the system is the Express Fast Charger. Express Fast Chargers can recharge a battery in as little as one hour, opportunity charging during predetermined breaks and between shifts will allow a single battery to do the work of two or more batteries without being changed out. Think of the timesaving's and increase in productive space by reducing or eliminating battery-charging areas! The second component of the fast charge system is the industry's first battery designed from the ground up to handle the demands of fast charging.
The Express Fast Charge Battery has several key features that allow for higher current carrying capability while minimizing the damaging heat associated with higher charge rates. Features such as a one inch post with copper inserts providing 72% more area than a standard post; specially designed double thick intercell connectors with copper inserts; and the Ironclad Square Tube technology that has the highest charge acceptance of any battery of similar size. Best of all, when you choose the Express Fast Charge System, the Express comes with an industry leading 4 year full warranty!
Exide Ironclad Batteries - Patented Design for Superior Performance
First introduced in 1910, the Exide Ironclad tubular plate design is well established as the performance leader. Exide Ironclad technology is a unique and exclusive square tube design that provides up to 84% more surface area depending on battery size. The Ironclad Effect means more usable power than a flat plate or round tube battery of the same six-hour rating.
The Superhog is the battery for your biggest, hardest jobs. This battery is especially well suited for the demands of cold storage applications, and will provide the power demanded by today's AC trucks.
The Loadhog was the first 100 amp-hour battery in an 85 amp-hour configuration. The Loadhog means high performance for long shifts.
The Deserthog is the premier low maintenance flooded battery in the industry, requiring watering only 4 times a year. Because of Exide's square tube technology, the Deserthog is the industry's only low maintenance flooded battery design that did not need to sacrifice battery life by changing the battery's chemistry to achieve longer watering intervals. When you have a medium to heavy-duty application that's not suitable for a sealed battery, Deserthog is the ideal choice.
The Workhog started a revolution in motive power over 90 years ago. With more power per rating than any conventional flat plate battery, the Workhog delivers extra work for standard applications.
The Smarthog line offers the industry's first 23" and 31" high, 80- and 120-AH fully sealed, and valve regulated lead-acid batteries. Clean, safe, and efficient, Ironclad Smarthog Batteries by EnerSys eliminate the need to remove vent caps, add water, or take hydrometer readings.
General Battery - The Trusted Brand for Reliable, Economic Power
Our General Series flat plate batteries meet the highest quality standards to provide you with the best product, at the best value. Each General Series Battery has numerous built in features to ensure outstanding performance. General Battery's HUP (High Utilization Positive) batteries feature a revolutionary design that provides up to 30% longer life. HUP batteries are so dependable they're backed by the longest standard warranty in the business. Our Renegade Batteries utilize the maintenance-free gelled technology and have the power to boost performance, economy, safety, and productivity.
EnerSys Chargers - A Complete Line of Chargers for Every Charging Need
It's a fact: most batteries do not wear out from discharging. They wear out from charging abuse due to undercharging or overcharging. EnerSys is one of the few companies to design and manufacture both batteries and chargers and provides a complete line of single-phase and three-phase chargers for every charging need. From our fully automatic Workhog Charger to the full feature Loadhog Charger, you can be confident your batteries are getting the best possible charge. Our rugged General and Exide chargers are designed with the benefits you've come to expect from the industry's largest Battery and Charger Company.
Strongest Service and Support Network in the Business
Whether you need help in selecting products, setting up a maintenance program, or designing a charging room layout, our experts are committed to meeting your needs with the largest company-backed team in the industry. More than 350 trained technicians staff a nationwide network of service locations and mobile vans. These service professionals have been thoroughly schooled in every aspect of battery and charger technology. We also return our technicians to the classroom every year for formal updates on changes in technology and new products. So when power counts, make sure you ask for only EnerSys Exide, General Battery, and Express fast charge products.
CONTACT DETAILS:
Website: www.enersys.com
