Cold robots revolutionise cold chain logistics
Frazer Watson -
Your Focus
- 13 Apr 2023 ( #1123 )
6 min read
Frazer Watson
Frazer Watson
Frazer Watson is VP sales - UK/Ireland at iFollow.
There are a number of factors that have tended to limit the effective deployment of automation in cold stores. But with design features addressing many of these issues, autonomous mobile robots (AMRs) offer a way forward in applying automation to improve cold store efficiency and productivity.
This has become critically important given how issues such as Brexit, the pandemic, the war in Ukraine, and the weather have each highlighted the role chilled and frozen warehousing has in creating resilience in our food supply chains; not forgetting, of course, how COVID revealed the centrality of low temperature storage in medicine and pharmacology. Research and development and many advanced industrial processes also depend on the ability to maintain goods and materials at low temperatures.
Efficiency in every way
‘Efficiency’ has several connotations. There is the efficient use of the available space. Many cold stores are quite small – often ‘cold rooms’ within larger buildings. But demand for cold space, from private companies’ own facilities to ‘public’ stores operated by a 3PL for multiple customers, is increasing. In the food chain in particular, companies from processors to distributors and retailers are looking for larger facilities – the Cold Chain Federation (CCF) has identified 678 units of over 50,000 sqft. (4,600 sqm), and there are many that are much larger still. But cold stores are expensive to build and equip, and although the CCF recently estimated that some 16.7 million sqft. (1.6 million sqm) of new space is under construction or being fitted out, that may not meet increased demand, especially as so much of the existing stock (34%) is over 25 years old and some of this is converted, not always very effectively, from other uses.
Cold stores must also be efficient in operation, which is key at a time of gas and electricity bills rising remorselessly. Although a well-built, -equipped and -run cold store uses a lot less energy than is commonly supposed, there is still an imperative to improve storage density and operations to minimise the heat coming in through open doors. And contrary to popular opinion, cold chain warehousing is not usually about minimally manned, long-term, bulk storage. Many cold chains move goods in and out of store rapidly, and involve all the break-bulk, order-picking, stock rotation and other operations familiar to ambient warehousing. That has to be performed just as efficiently and productively, but in much more arduous conditions.
This means that labour, too, has to be deployed efficiently. Logistics UK last October claimed that “13% of traders are reporting severe warehouse staff shortages”; in November, the Cold Chain Federation noted “10% to 20% shortage rates” among its members. The pool of workers prepared to perform arduous, even hazardous, tasks in cold conditions is decreasing. In addition, there is an increasing realisation of the need to limit the length of time that workers spend in the cold before taking a break in warmer areas, and of the long-term impacts of heavy manual tasks in cold conditions.
AMR in cold store
AMR in cold store
Overcoming technical issues
Given all this, the cold store would seem an obvious arena for the introduction of automation. But this is not without its problems. There are technical issues – operation at low, and especially sub-zero, temperatures, can embrittle and otherwise degrade materials including metals, plastics and rubber tyres. Electric and electronic components can be affected by ice and condensation. Batteries, in particular, have degraded performance and shorter lives at low temperatures. Fixed mechanisation, such as conveyors, takes up refrigerated space that isn’t being used to store the goods. There are safety and operational issues too – it isn’t easy to perform complex control operations, or to ensure that people are adequately protected from machinery, when workers are wearing heavy and cumbersome protective clothing and both their physical and mental agility may be compromised by the low temperatures alongside the hazards of condensation and ice.
Not all AMRs can work in cold storage. However, manufacturers like iFollow produce a range of robots for cold chain logistics that transport specific to the cold store environment. Depending on the size of the AMR, between 12 and 18 hours of autonomous operation are available from a two-hour charge time. Fewer battery charges or changes obviously improve productivity, but also reduce the space needed for recharging.
Using AMRs rather than ride-on vehicles eliminates the known hazards of the latter – present in any warehouse operation but exacerbated in cold and slippery conditions. Specialised cold-store standard trucks are also not cheap.
Operator control is also suited to cold store conditions. It is not reasonable to expect workers to input complex instructions while wearing heavy gloves or to require them to take their gloves off for extended periods. There are a range of apps which are compatible with all available WMS/ERP systems, and can be used through any computer or smartphone with most instructions available through just one or two clicks.
AMRs do not require the segregated space of conveyor-based systems and they can turn in their own footprint, unlike most AGVs which require a defined bend to corner. This maximises storage space, or to put it another way, minimises the volume of fresh air being refrigerated. Also, unlike AGVs, AMRs do not require semi-permanent predefined pathways, thus allowing a more flexible use of warehouse space. They also do not require especially smooth and even floors – an issue with some older or converted cold stores – indeed, implementation doesn’t usually require any expensive infrastructure at all.
The ability for an AMR to carry two roll cages at once, to a maximum load of 1,500kg, offers an advantage, particularly in the cold store environment, because it reduces the number of times doors have to be opened and closed. That not only reduces energy loss and minimises the potential for condensation, but reduces the hazard from the, typically, fast-acting cold store doors.
Collaborative order picking
The AMRs are designed with safe, collaborative use in mind. Lidar navigation prevents the vehicle from colliding with permanent fixtures, with goods left blocking aisles, or, of course, with the attendant workforce (who, clad in thermal headgear, may not always be aware of the traffic around them). Typical maximum speed is 1.7m /s – a brisk walking pace – with linear and angular speeds and accelerations closely controlled.
In typical order-picking use, one operator might work with two AMRs within a defined pick zone, selecting items to roll cages or destinations. The operator can receive pick-list instructions by voice terminal, RF terminal or tablet, and, of course, the AMRs are simultaneously receiving their complementary movement instructions. Picking this way can yield 90% better productivity than the conventional manual approach, while optimising the picker’s movements. AMRs can equally be used for the variety of shuttle movements required in the store, moving goods between locations. Through an intuitive fleet management interface, the scenario can be simply generated, and the robotic system works out the movements required.
AMRs, then, can improve the efficient use of cold store space both by increasing productivity and minimising ‘wasted’ space. The latter, along with reduced door openings, helps with energy efficiency, as does the non-degrading battery performance.  The efficiency of scarce and increasingly expensive labour is maximised, and, perhaps most importantly, the safety and welfare of both goods and staff is addressed. There is a clear logic in letting AMRs carry the load in cold stores.
Also Read:
Five factors that turn forklift safety from compliance into commitment
Joe Bolduc
4 minute read
Five factors that turn forklift safety from compliance into commitment Safety First - 11 Jun 2026 (#1285) Joe Bolduc is the safety guy at Velocity Maintenance, where he leads safety and risk across the company's material handling and warehouse maintenance operations. He brings more than 30 years’ of EHS leadership across manufacturing, construction and logistics.
Nothing was out of place
Russ Niedzwiecki
2 minute read
Nothing was out of place Safety First - 4 Jun 2026 (#1284) After a forklift tipover, the questions are usually the same: What went wrong? Was the operator going too fast, carrying a load too large, or was the floor wet? Russ Niedzwiecki, corporate safety trainer with TrainMOR, has more than 26 years’ experience and has delivered operator training on industrial trucks and MEWPs to over 20,000 people across more than 1,000 companies.
What triggered the battery revolution - how falling LFP prices made electric forklifts the only logical choice
Maxim Khabur
3 minute read
What triggered the battery revolution - how falling LFP prices made electric forklifts the only logical choice Your Focus - 21 May 2026 (#1282) Max Khabur is the marketing director with Eneroc USA, and has held the elected role of chairman of the Advanced Energy Council, representing a group of companies.
Linde Material Handling
