Yale GLC120 Fault Codes 524225-0 & 524269-7
Hi- I have a Yale GLC120VXNGSE100 showing faults 524225-0 and 524269-7. It will start and move in forward and reverse but with any acceleration in forward 524225-0 appears and truck won't move. Panel says shutting down. What is this fault? Thank you.
  • Posted 7 Jun 2016 03:20
  • By TKO5855
  • joined 4 Jun'16 - 9 messages
  • Wisconsin, United States
Thanks Brewski. For any following this post now or later with the same codes...a service tech replaced a switch in this truck and was finished within an hour. Vehicle back up and running. I'll post again any specifics I get back from technician.
  • Posted 8 Jun 2016 04:23
  • By TKO5855
First code is forward pressure greater than demanded, second code is enable valve failure. Hope this helps.
  • Posted 7 Jun 2016 22:44
  • By BREWSKI
Hawker Powersource, Inc.
