Won’t move forward
My forklift won't move when put into gear. Getting codes -68 and sometimes -11. I just bought this thing 2 days ago. I want to know how screwed I am or if I should just get rid of it. I bought it from a factory and they would not let me drive it with the insurance supposedly. But I saw they drive it very briefly. When I got the forklift off the trailer it worked then would stop. And work. I was just able to get it up the road 20 feet and just would not go anymore foward. I figured just the battery. Charged it up and now won't move at all. The mast is perfect though. Any help will be greatly appreciated.
Update. I found a wire that looks to be disconnected, but I don't see where it would go.
  • Posted 22 Apr 2024 05:20
  • By Nickforklift40
  • joined 22 Apr'24 - 3 messages
2004 Crown SC4000 Owner
Check fu1.
  • Posted 24 Apr 2024 00:03
  • By marcos_m
  • joined 25 Feb'19 - 114 messages
Thanks
I don't think I am able to post a picture of the forklift so you can see what I see. I don't see anywhere at all where there is a wire that connect to there.
  • Posted 23 Apr 2024 06:40
  • By Nickforklift40
Check that the black wire isn't for accelerator pedal, if it's not you may wanna have your local Crown dealer road tech plug it in, they can tell you if it's bad or not
  • Posted 23 Apr 2024 05:03
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
I think this post is about an SC4000 not a SP4000
  • Posted 23 Apr 2024 04:27
  • By DyslexicNerd_01
  • Wisconsin, United States
A SP4000 doesn't have a seat belt or seat switch
  • Posted 23 Apr 2024 04:04
  • By marcos_m
Code -11 is accelerator switch is closed during power up. Possible short between CA205-3 and battery positive.
Code -68(-66) is a drop in voltage from mrc1 and mrc2. Check cable connections for both drive motors. Test both drive motors for shorts. Replace as necessary.
Hope this helps!
  • Posted 22 Apr 2024 22:21
Check that the wires under hood going to seatbelt and seat switch look intact
  • Posted 22 Apr 2024 22:11
  • By Matthew_Reed
Yes but the code comes up as soon as you put the key on. I found a black wire that looks disconnected from something. But nothing to where it goes.
  • Posted 22 Apr 2024 20:10
  • By Nickforklift40
I'll admit, I'm no Crown expert, however, does all lift functions operate without codes?, When does code arrive, after engaging direction or after trying to accelerate?
  • Posted 22 Apr 2024 13:47
  • By Matthew_Reed
Sue Tomic Sue Tomic
