Hyster E120XL:
Won't lift higher than 30 inches
Won't lift higher than 30 inches every time, everything else works, new pumps.
Would the check valve in the bottom of the rod cause this? Any ideas would be appreciated.
Serial number C098V03441R
  • Posted 14 Sep 2024 06:04
  • Discussion started by jason_g
  • Illinois, United States
Jason,
If the lift runs on a 36 volt battery, the voltage should be reading 37 to 38 volts charged. If it reads 36 volts the battery needs to be charged. The hydraulic tank is under the operator floor board. Could be on the left or right side. With mast fully lowered check the dipstick. Top off tank until full. Should take hydraulic oil 32, newer lifts take 46.
  • Posted 26 Sep 2024 03:29
  • Reply by Fishmech
  • Virginia, United States
Okay, both pumps are running, oil is full and battery is at 40%
  • Reply by jason_g
Jason,
Those switches should be turning on the pump motor as soon as they are pushed. Since this is an electric lift, what is the battery voltage and have you checked the oil level? Thanks.
  • Posted 26 Sep 2024 03:24
  • Reply by Fishmech
There is no switch to press. Theres a cover below the control handles, behind the cover there are rods connecting the handles to the control valve. it looks like each function only has one switch?
  • Posted 26 Sep 2024 03:20
  • Reply by jason_g
Yes, you will need to press the switch to go higher than the preset limit.
  • Posted 26 Sep 2024 03:10
  • Reply by Fishmech
Do the switches on the control levers work work like limit switches?
  • Posted 26 Sep 2024 03:07
  • Reply by jason_g
Jason,
The lift should have a main pressure at 3000 PSI. Even with the pressure at 2000psi the forks should raise up and down the full length of the rails. Check the handles going to the valve and make sure nothing is broken. You could have a failed hydraulic line that is causing a partial blockage. Please verify the hydraulic oil is at the proper level. Good Luck
  • Posted 26 Sep 2024 02:58
  • Reply by Fishmech
Hyd oil is full with new filter
Carriage rollers appear to be in tact and there is no foreign debris
The carriage will raise 20 inches and will slow down after 15 inches or so. After the carriage stops I release the lift lever and give it a second and pull the lift lever again, it will go up another foot and stop and will not go any higher. The pressure will read anywhere from 1k to 2500psi at that time.
  • Posted 26 Sep 2024 02:51
  • Reply by jason_g
1- yes, it is new to me
2- yes, it did
It does not have a limit switch on the mast. There are no buttons on or around the lift switch and the lift cylinder has no external dents or signs of damage.
This has primary and secondary relief valves. 2k psi is the most i've been able to get out of it even after dead heading the lift line.
  • Posted 26 Sep 2024 02:37
  • Reply by jason_g
A couple of questions
1- is this unit new to you ? Have you had it a while ?
2- did it lift higher in the past?
I ask because some units had a lift shut off at set height for certain customers a limit switch
Mounted on mast to cut it off at a set height
Also had a button on the lift lever you pushed to over ride the lift limit of set height
If not then look at lift cyl tube for dents
If it was damaged it will only go to the height of the ding and stop the rod from passing
The damaged area
  • Posted 18 Sep 2024 11:35
  • Reply by John_Bradley
Jb69
Jason,
Let's start with basics. Hydraulic fluid level will affect lifting height. Have you completed a pressure check after installing new pumps? I assume there is nothing stuck in the mast or any broken rollers. Suspect something has come apart inside the cylinder to cause an exact stop. Make sure to replace all internal valves. Good Luck
  • Posted 16 Sep 2024 22:23
  • Reply by Fishmech
Jefferson, WI, United States
St. Louis, MO, United States
Johnston, IA, United States
edition #1234 - 12 June 2025
