will not move
lift has sat for a couple of months and will not click or make any noise now at all, the lift has not had a lot of use
  • Posted 7 Jan 2014 09:04
  • By jmbo
  • joined 7 Jan'14 - 4 messages
  • Washington, United States
I would also check the parking brake switch. They are know for the arm getting bent up.
  • Posted 9 Jan 2014 12:03
  • By rogeriwt
contact your local clark parts dept and ask for the schematic for your machine.
  • Posted 9 Jan 2014 04:11
  • By jmbo
I'm almost in the same boat. Mine sits or creeps and then takes off, jolting. I can see the double contact kick in and spark went it does move, but won't go over a 2 X 4. Theres a tm12 forum thats close to this problem.
I need to buy manual somewhere. Help Please
  • Posted 8 Jan 2014 16:32
  • By pineddy
  • joined 8 Jan'14 - 12 messages
  • Nevada, United States
Fix it like it's your own equipment!
there is no seat switch i will check the foot brake switch and i am not sure on the ev100
  • Posted 8 Jan 2014 02:41
  • By jmbo
the foot brake switch could be bad or seat/parking brake switch if it has them, i dont think it does. this is ev100 right?
  • Posted 7 Jan 2014 10:04
  • By stam
the battery is charged and the forks do lift up and down just the forward and reverse do not work at all sorry i should have given you more info on that. the battery shows on the gauge that it has a good charge
  • Posted 7 Jan 2014 09:19
  • By jmbo
is your battery charged? if the truck is sitting doing nothing it should not have a problem unless it did before it was parked. the battery can get damaged from this though.
  • Posted 7 Jan 2014 09:15
  • By stam
