Will not get out of neutral no rev or fwd
Lift will not go into fwd or rev. Stays in neutral position. All fuses are good. Any ideas?
Sn: B875b16125F
  • Posted 12 Jun 2014 23:36
  • By Rmullis
  • joined 8 Jan'14 - 15 messages
Russell mullis
Atlantic Forklift Services
Charlotte, Nc
Mullis.russell@gmail.com
7042967564
does it have a monotrol pedal? --- ?park brake switch?
  • Posted 13 Jun 2014 21:24
Hi Rmullis,
Is there no fault code shown with this problem, if not it would suggest that no direction had been selected, in which case the direction switch may be faulty, these switches are not wired but magnetic, these switches just pull out from the housing but do it carefully you should be able to swop it with the indicator switch. Try that see if you get a result, if you can access the error log there may be some fault codes logged and may need deleting or rectifying.
Nero
  • Posted 13 Jun 2014 04:06
  • By NER045
Toyota 02-8FD30
Nagano NUL120-6
Toyota 02-8FD30
Nagano NUL120-6
Hangzhou Maxlion Forklift Imp & Exp Co., Ltd.
Mohammed Kabir Mohammed Kabir
Chief executive officer, Corvus Robotics
Regional sales manager, Abbey Attachments
vice president of human resources, Big Joe Forklifts
Board of Directors, UKMHA
